POSIX : pthread_attr_t structure
Thu Dec 7 16:46:38 UTC 2000
"Andrew N. Sloss" wrote:
> sorry: 'definitely' should have been 'differently'
> At 08:13 AM 12/7/00 -0800, Andrew N. Sloss wrote:
> >Hi,
> >I'm attempting to build the POSIX library and I've hit a problem
> >that pthread_attr_t appears to be defined definitely from that
> >used by pthread.c.
> >Can anyone point me to a location where the correct header
> >definition is located.
pthread.h was in RTEMS but has bene moved to newlib.  In spite
of this there have been no changes to this file in a long time.
What problem are you seeing specifically?
> >many thanks,
> >-- andrew
