m360 networking
Mon Dec 11 15:15:51 UTC 2000
Eric Norum wrote:
> Mirko Markov wrote:
> > Is there some way to add driver for second network in BSP (m360 based
> > on gen68360 BSP)? I know how to deal with hardware configuration
> > (i. e. settings in network.c), but have no idea how to attach second
> > driver to the rest of the RTEMS. I'm planning to use scc2 for second
> > network.
> You'll have to modify network.c to support two SCCs -- tedious but
> fairly straightforward.  If you want you could just copy all of
> network.c to network2.c and make the appropriate changes.  This would
> use a little more space since none of the code that could be shared
> would be shared, but would be the easiest way to modify the driver.
Not knowing the m360 scc's in details .. Are the two SCCs similar
enough that the libchip trick of wrapping a core chunk and passing
instantiation specific data (like base address and state) in to
support routines would work?
Check out the libchip/network/sonic* and powerpc/dmv177/network
to see one way to do this.
> Then you need to make two entries (three if you're using the loopback
> interface) in the network configuration.  The drivers are configured as
> a linked list.  The networkconfig.h in the netdemos shows how to link
> driver configuration structures together.
> Eric Norum                                 eric.norum at usask.ca
> Department of Electrical Engineering       Phone: (306) 966-5394
> University of Saskatchewan                 FAX:   (306) 966-5407
> Saskatoon, Canada.
