Make Problem with FS flash
correo at fernando-ruiz.com correo at fernando-ruiz.com
Mon Dec 11 20:45:34 UTC 2000
-----Mensaje original-----
De: joel [mailto:joel]En nombre de Joel Sherrill
Enviado el: lunes, 11 de diciembre de 2000 17:25
Para: fernando.ruiz at ctv.es
CC: 'Rtems-Users (E-mail)
Asunto: Re: Make Problem with FS flash
Lots of questions .. :)
"Fernando RUIZ CASAS (E-mail)" wrote:
> Hi rtems members,
>   I try build a FS flash file system.
>   The flash driver works ok with a sector erase cache memory.
>   It is not a harddisk but it works very well.
Be warned .. the IMFS is not as block oriented as it needs to
be to store all data in Flash.  I posted on this a while back.
See
http://www.oarcorp.com/rtems/maillistArchives/rtems-users/2000/november/msg0
0034.html
Thanks for your answer but I think to work in a fmfs in order to build a
complete block oriented filesystem because I need a definitive tool to store
in standard way the information. IMFS is only the starting point to build
the new filesystem. Only the skeleton, not the meat.
I have the basis but the rtems structure tree is sometimes complicated to
build
the new ideas.
I think first in a extfs flopy disk system (only the information). Working
with this
to translate the concept in a user program and after touch the imfs until to
convert into fmfs.
When I work in total liberty in the user environment I can obtain these
results (a filesystem)
but I need adopt the rtems drivers philosophy because with the multitask
environment this is necesary.
Fernando RUIZ CASAS
