RTEMS + g++ + #include <netinet/in.h>
Ralf Corsepius corsepiu at faw.uni-ulm.de
Thu Dec 21 03:50:11 UTC 2000
Chris Johns wrote:
> Ralf Corsepius wrote:
> > Try m68k-rtems-g++ -isystem /opt/rtems/rtems/bare-5200/lib/include
> > -c tst.cpp
> This worked.
Fine.
> > or (preferred)
> > m68k-rtems-g++ -B/opt/rtems/rtems/bare-5200/lib/ -c tst.cpp
> This did not.
This is supposed to work :)
Did you have the trailing slash at the end of the -B parameter?
> I already use the -B option and a specs file option. Does
> this cause a problem ?
I am not sure, but the order may matter.
Try adding -v to the compiler's flags.
It should tell you all the "glory details" about how -B <path>/lib/
gets expanded. This normally includes prepending -isystem
<path>/lib/include.
Ralf
Ralf Corsepius
Forschungsinstitut fuer Anwendungsorientierte Wissensverarbeitung
(FAW)
Helmholtzstr. 16, 89081 Ulm, Germany     Tel: +49/731/501-8690
mailto:corsepiu at faw.uni-ulm.de           FAX: +49/731/501-999
http://www.faw.uni-ulm.de
