Questions with RTEMS install on WinNT - Cygwin
Jowell, Chris {AVL~Roswell}
CHRIS.JOWELL at ROCHE.COM
Tue Dec 26 15:37:41 UTC 2000
Hi,
I'm trying to install RTEMS (M68K target) on a WinNT - Cygnus
platform and I'm slightly confused:
1st The FAQ describes unpacking various tarballs and then applying patches
to them. However poking about OAR's ftp site I've found tarballs labeled
"rtems-base" and "m68k-rtems"
What are these and how do I use them?
2nd The FAQ specifies version 2.9.5.0.24 of binutils (and all of those
interesting tarballs I found are the same version) but the VA Research FTP
site listed has long since moved on to newer versions
Where else can I find that specific version?
Thanks
Christopher Jowell
Application System Analyst
Roche Diagnostics
235 Hembree Park Dr.
Roswell Ga 30076
(770) 576-5000 X 579
(770) 576-5020 Fax
URL: <http://lists.rtems.org/pipermail/users/attachments/20001226/289df809/attachment.html>
