driver APIs
Fernando RUIZ CASAS correo at fernando-ruiz.com
Fri Dec 29 21:03:59 UTC 2000
> -----Mensaje original-----
> De: Aaron J. Grier [mailto:aaron at frye.com]
> Enviado el: viernes, 29 de diciembre de 2000 4:06
> Para: Fernando RUIZ CASAS
> Asunto: Re: driver APIs
> On Thu, Dec 28, 2000 at 10:36:47PM +0100, Fernando RUIZ CASAS wrote:
> > After several tries I have writed drivers for flash memory, e2prom
> > (serial like I2C memory), termios 16450 UART and several remote
> > consoles, multiuser environment, etc...
> > Are you interested? My sources are for you if you are interested.
> ¡sí, por supuesto!  :)
> I have i²c EEROM, flash, and a 16550 serial port on my 68331-based
> target.  if your exact hardware is different than mine, it would still
> be good to maintain a consistent driver API for things like flash and
> EEROM.
> > RTEMS works very well. I am developping a multicpu (serial linked)
> > telephonic concentrator (public interphone, normal telephony and
> > command telephone) in a prototype. All of drivers works correctly.
> > I would contribute to RTEMS with the sources but I have a problems
> > because RTEMS need sources independent of BSP. I need build the
> > sources into ../libchip/.. directory and the sources
> configurables for
> > all BSP. Now my efforts are based in to develope my BSP. After the
> > generalization of drivers.
> Yes.  :)  I am also at this stage with my drivers.
>   Aaron J. Grier   |    Frye Electronics, Tigard, OR   |
> aaron at frye.com
>     "Calling anything from the x86 world a 'masterpiece' seems, to me,
>      like putting a gold star on the best-looking
> fingerpainting in the
>      special-needs Kindergarten class."  --  Wakko Warner
Do you want see my driver sources and to share the background?
Perhaps our efforts can be reduced if we share the information to build the
same
objectif.
Don't have a little source code to start in the world of drivers is very
hard.
We can share it.
I have a web page to put it.
My problem is the english.
Can you translate my spanish?
Best regards.
Fernando RUIZ CASAS
