SH Question
Ralf Corsepius
corsepiu at faw.uni-ulm.de
Sat Dec 30 21:24:12 UTC 2000
Joel Sherrill wrote:
> > > I would also think that the /dev/null driver could be moved to a
> > > non-SH directory.
> > /dev/null is for a simulated link to console because the hard links are not
> > present
> > when Ralf(?) writed it. (I suppose)
Yep, it was me who introduced it (It is a moderately modified copy
of the test suite's stub driver). And you are right, RTEMS did not
have any filesystem when this was introduced.
> > /dev/null is better to place it with /dev/stub in (?).
No. /dev/null is supposed to be what its name says: /dev/null
What we did when porting the RTEMS to the SH1 was to redirect RTEMS
/dev/console to /dev/null, similarily to using a symlink/hardlink
from /dev/console to /dev/null under unix, but without having nor
_needing_ a filesystem (SH1 are low memory systems :).
We did so, because we wanted to be able to
* run RTEMS without having a physical console attached.
* run RTEMS without having to assign _any_ physical device to a
/dev/console.
* run RTEMS without having _any_ console driver.
* and wanted to be able to assign different physical devices to
/dev/console but serial devices.
Furthermore, in general, many embedded systems do not have any
console device, however RTEMS currently (IMO: incorrectly) assumes a
console always to be present.
> /dev/stub is a test fixture and is in the test source tree.
> I think /dev/null could go in libmisc without too much
> worry.
I wholeheartily agree.
Ralf
Ralf Corsepius
Forschungsinstitut fuer Anwendungsorientierte Wissensverarbeitung
(FAW)
Helmholtzstr. 16, 89081 Ulm, Germany Tel: +49/731/501-8690
mailto:corsepiu at faw.uni-ulm.de FAX: +49/731/501-999
http://www.faw.uni-ulm.de
