can't create include/syslimits.h
Nick.SIMON at syntegra.bt.co.uk
Tue Feb 1 06:51:32 UTC 2000
> -----Original Message-----
> From: Smith, Gene [mailto:Gene.Smith at sea.siemens.com]
> Sent: 01 February 2000 00:48
> To: rtems
> Subject: cp:can't create include/syslimits.h
> I am trying to run the "./bit i386" script and after a long
> while I get the
> following error:
> cp: cannot create regular file 'include/syslimits.h' : No such file or
> directory
<snip>
> I added the line "mkdir include" to the file
> tools/build-i386-tools/gcc/Makefile at the place where the
> problem occurs,
> however, the file gets recreated by the script so it seems
> that adding the
> line had no effect.
> If the suggested patch is the correct fix, which file should
> the patch be
> applied to?
Take a look in tools/src/gcc/Makefile.in - I think that's the one you want
(I can't be sure without rebuilding).
> -Thanks,
> Gene Smith
You're welcome.
-- Nick Simon
