failed while compiling ../../../../../rtems-4.0.0/c/src/lib/libc/readdir.c
Serrae at tsainc.com
Wed Feb 2 16:23:54 UTC 2000
Hello folks,
----- Begining of make.out -----
/export/home/u1/eserra/projects/rtems/egcs-1.1.2-binutils-2.9.1-newlib-1.8.1/sparc-rtems/bin/sparc-rtems-gcc
--pipe -mcpu=cypress -Wall -ansi -fasm -g
-B/export/home/u1/eserra/projects/rtems/tools/build-sparc-rtems/erc32/lib/
-specs bsp_specs -qrtems -O4 -c -o o-erc32/readdir.o
In file included from
/export/home/u1/eserra/projects/rtems/egcs-1.1.2-binutils-2.9.1-newlib-1.8.1/sparc-rtems/sparc-rtems/include/dirent.h:4,
from
../../../../../rtems-4.0.0/c/src/lib/libc/readdir.c:7:
/export/home/u1/eserra/projects/rtems/egcs-1.1.2-binutils-2.9.1-newlib-1.8.1/sparc-rtems/sparc-rtems/include/sys/dirent.h:12:
No include path in which to find dirent.h
../../../../../rtems-4.0.0/c/src/lib/libc/readdir.c:10: warning: type
defaults to `int' in declaration of `DIR'
../../../../../rtems-4.0.0/c/src/lib/libc/readdir.c:10: parse error before
../../../../../rtems-4.0.0/c/src/lib/libc/readdir.c: In function `readdir':
../../../../../rtems-4.0.0/c/src/lib/libc/readdir.c:13: `NULL' undeclared
(first use in this function)
../../../../../rtems-4.0.0/c/src/lib/libc/readdir.c:13: (Each undeclared
identifier is reported only once
../../../../../rtems-4.0.0/c/src/lib/libc/readdir.c:13: for each function
it appears in.)
../../../../../rtems-4.0.0/c/src/lib/libc/readdir.c:14: warning: control
reaches end of non-void function
make[4]: *** [o-erc32/readdir.o] Error 1
make[3]: *** [all] Error 1
make[2]: *** [all] Error 1
make[1]: *** [all] Error 1
make[1]: Leaving directory
`/export/home/u1/eserra/projects/rtems/tools/build-sparc-rtems/c'
make: *** [all] Error 1
eserra at sun250$
----- End of make.out -----
Sincerely,
Efren
Efren Serra
Software Engineer
Systems Solutions Group
Transaction Systems Architects, Inc.
218 South 108th Avenue
Omaha, NE 68154
Phone: 402-697-2267
FAX: 402-333-9725
