pc386.cfg ERRORs
Erwin Rol
Erwin.Rol at q-soft-engineering.com
Wed Feb 9 15:37:49 UTC 2000
Hello All,
i had some problems with 4.5-BETA1a and pc386 BSP.
in pc386.cfg there are a number of $ missing before variables
LIB_VARIABLE.
and the bootimage path isn't created fully so i added a -D to the
install commant.
- Erwin
Q - S O F T - E N G I N E E R I N G
Rodachtalweg 11, 81549 Muenchen, Germany
Erwin Rol (Software Engineer) phone: +49-89-68050051
Erwin.Rol at Q-Soft-Engineering.com fax : +49-89-68050052
# Config file for the PC 386 BSP
# $Id: pc386.cfg,v 1.23 2000/02/08 14:00:45 joel Exp $
include $(RTEMS_ROOT)/make/custom/default.cfg
RTEMS_CPU=i386
ifeq ($(RTEMS_CPU_MODEL),)
RTEMS_CPU_MODEL=i386_fp
endif
# This is the actual bsp directory used during the build process.
RTEMS_BSP_FAMILY=pc386
# This contains the compiler options necessary to select the CPU model
# and (hopefully) optimize for it.
# NOTE: CPU_CFLAGS is set by pc386 variants.
# CPU_CFLAGS =
# optimize flag: typically -0, could use -O4 or -fast
# -O4 is ok for RTEMS
# -fomit-frame-pointer breaks debugging and C++ exceptions
CFLAGS_OPTIMIZE_V=-O4
# This section makes the target dependent options file.
# NDEBUG (C library)
# if defined asserts do not generate code. This is commonly used
# as a command line option.
# RTEMS_TEST_NO_PAUSE (RTEMS tests)
# do not pause between screens of output in the rtems tests
# RTEMS_DEBUG (RTEMS)
# If defined, debug checks in RTEMS and support library code are enabled.
define make-target-options
@echo "/* #define NDEBUG 1 */ " >>$@
@echo "/* #define RTEMS_TEST_NO_PAUSE 1 */" >>$@
@echo "/* #define RTEMS_DEBUG 1 */" >>$@
endef
# Here is the rule to actually build a $(ARCH)/foo.exe
# It also builds $(ARCH)/foo.sr and $(ARCH)/foo.nm
# Usage ref: src/tests/sptest/sp1/Makefile
#| Set the value of RELOCADDR to the address where you want your image to
#| load. If you'll be using GRUB to load the images it will have to be >=
#| 0x100000 (1024K). If you are using NetBoot to load the images it can be
#| >= 0x10000 (64K) AND <= 0x97C00 (607K) OR >= 0x100000 (1024K). The memory
#| top is of course another limit. Make sure there is enough space before the
#| upper memory limits for the image and the memory allocated by it to fit.
#| Make sure the value you choose is aligned to 4 bytes.
RELOCADDR=0x00100000
START16FILE=$(PROJECT_RELEASE)/lib/start16$(LIB_VARIANT).bin
START16ADDR=0x00097C00
HEADERADDR=0x00097E00
# The following are definitions of make-exe which will work using ld as
# is currently required. It is expected that as of gcc 2.8, the end user
# will be able to override parts of the compilers specs and link using gcc.
ifeq ($(RTEMS_USE_GCC272),yes)
define make-exe
$(LD) -N -T $(LINKCMDS) -Ttext $(RELOCADDR) -e start -nostdlib \
-o $(basename $@).obj \
$(START_FILE) $(LINK_OBJS) --start-group $(LINK_LIBS) --end-group
$(OBJCOPY) -O a.out-i386 \
--remove-section=.rodata \
--remove-section=.comment \
--remove-section=.note \
--strip-unneeded $(basename $@).obj $@
$(OBJCOPY) -O binary $(basename $@).obj $(basename $@).bin
$(BIN2BOOT) -v $(basename $@).bt $(HEADERADDR)\
$(START16FILE) $(START16ADDR) 0 $(basename $@).bin $(RELOCADDR) 0
$(NM) -g -n $(basename $@).obj > $(basename $@).num
$(SIZE) $(basename $@).obj
$(INSTALL_PROGRAM) -D -m 555 $(basename $@).bt \
${PROJECT_RELEASE}/BootImgs/$(basename $@)$(LIB_VARIANT).bt
endef
else
define make-exe
$(CC) $(CPPFLAGS) $(CFLAGS) $(CFLAGS_LD) -Wl,-Ttext,$(RELOCADDR) \
-Wl,--oformat,elf32-i386 -o $(basename $@).obj \
$(LINK_OBJS) $(LINK_LIBS)
$(OBJCOPY) -O elf32-i386 \
$(PROJECT_TOOLS)/bin2boot -v $(basename $@).bt $(HEADERADDR)\
@$(mkinstalldirs) ${PROJECT_RELEASE}/BootImgs
-o $@ $(LINK_OBJS) $(LINK_LIBS)
endef
define make-cxx-exe
$(CXX) $(CPPFLAGS) $(CFLAGS) $(CFLAGS_LD) -Wl,-Ttext,$(RELOCADDR) \
-o $(basename $@).coff $(LINK_OBJS) $(LINK_LIBS)
endef
endif
# Miscellaneous additions go here
# BSP-specific tools
BIN2BOOT=$(PROJECT_TOOLS)/bin2boot
