Bug with pthreads
Peter Pointner
pr at schenk.isar.de
Tue Feb 22 17:43:08 UTC 2000
Hello,
I think there is a bug somewhere in the posix api:
a) exec/posix/src/pthread.c, _POSIX_Threads_Manager_initialization() calls
_Objects_Initialize_information with parameter 'is_string' set to TRUE.
b) exec/posix/src/pthreadcreate.c, pthread_create() defines
char * default_name = "psx";
on the stack, then calls
_Thread_Initialize( ..., &default_name);
c) exec/score/src/threadinitialize.c, _Thread_Initialize() gives this
parameter to the macro _Objects_Open
d) exec/score/macros/rtems/score/object.inl, _Objects_Open() decides
(based on the information from a) ), to pass this parameter to
_Objects_Copy_name_string
e) exec/score/src/objectcopynamestring.c, _Objects_Copy_name_string treats
the value as pointer to a null terminated string and copies it.
If I didn't get something wrong, this might lead to unpredictable results,
if this '&default_name' doesn't contain a null byte.
I'm a bit too confused now to fix that. Any takers?
Peter
