How obtain "times" informations
John M. Mills jmills at tga.com
Thu Feb 10 14:46:52 UTC 2000
Silverio -
On Thu, 10 Feb 2000, Silverio Diquigiovanni wrote:
> In each bsp of libbsp exist a file called "times" in which are
> archivied the performance of SO with that CPU/BSP.
> How are obtained ?
> I want to calculate they for my BSPs in SH1 and SH2.
I don't remember where this was discussed, but I got them roughly as
follows:
 1) edit the file: 'rtems/c/src/lib/libbsp/<CPU>/<BSP>/include/coverhd.h',
    setting all the times in that file to zero;
 2) rebuild RTEMS, ensuring that the test suite is built, but don't
    necessarily install the new build;
 3) run '<BLD_DIR>/<BSP>/tests/tmoverhd.exe' and capture the output;
 4) put the values produced in the test's output back into 'coverhd.h',
    along with notes as to the configuration you ran; and
 5) rebuild RTEMS and this time you may install it.
Hope that works, or that someone will correct me if I mis-remembered.
 - John
  John Mills, Sr. Software Engineer
  TGA Technologies, Inc.
  100 Pinnacle Way, Suite 140
  Norcross, GA 30071-3633
  e-mail: jmills at tga.com
  Phone: 770-441-2100 ext.124 (voice)
         770-449-7740 (FAX)
> Thank you very much !
> Silverio
