does there exist a way to calculate time spent on interrupts handling ?
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Feb 11 13:55:48 UTC 2000
Kirill Korotaev wrote:
> Hi, everyone!
> I know there is CPU_usage_Dump() function to dump thread cpu usage. But can
> I
> easily dump interrupts cpu usage? I think this should be important for RTOS.
There is currently no generic RTEMS mechanism for accounting for time
spent
in ISRs.
In case you did not notice the CPU_usage report is based on noticing
which task is running when the clock ticks and as a direct result is
only an approximation. It is safe to assume that multiple tasks can
and often do execute between two consecutive clock ticks. Did each
of those tasks take 0 clock ticks or 1 clock tick to execute?
There needs to be a higher granularity timestamp to make this completely
accurate and to account for time spent in ISRs.
Adding this capability and defining the infrastructure required to
portably support this would be a nice thing. :)
> Kirill
joel at OARcorp.com On-Line Applications Research
