Untar: Memory problem with big files (800k) in RTEMS filesystem: simple trial!]
Jake Janovetz
janovetz at tempest.ece.uiuc.edu
Fri Feb 11 14:11:12 UTC 2000
Oscar,
As I recall, Joel set the maximum file size (through a
heirarchy of three blocks) to something like 278kBytes. Have
you overridden this yet? Untar was written without a whole
lot of error-checking, so it probably won't tell you specifically
what went wrong.
If you look in c/src/lib/libc/imfs.h, you can find how the
file size relies on the number of block slots and the number of
bytes per block. If you've already done all this, I can take
another look at the untar code and test it a bit with bigger files.
Cheers,
Jake
On Fri, Feb 11, 2000 at 11:16:08AM +0100, Oscar Martinez de la Torre wrote:
> Hi!
> I'm trying to use Kaffe with RTEMS on ERC32.
> As I need a filesystem with the .class file and Klasses.jar
> I tar them and ld and link with the executable (Kaffe0.exe)
> But I have found several problems because of the
> untar function and memory.
> Is anyone working with filesystem and big files (1Mb)?
> I'm using linux and RPMs of snapshot 19991203!
> Below, I tell you more details!
> Thanks,
> Oscar
> In order to test and isolate the problem, I have taken
> a simple program (test.c I attach it) which works pretty good
> It untars, reads and write a small file (hola)
> So, I haved added several files which I use with Kaffe!
> -rwxr-xr-x 1 omt wms 2601580 Feb 11 10:06 Kaffe0.exe
> -rw-r--r-- 1 omt wms 885137 Feb 11 10:05 Klasses.jar
> -rwxr-xr-x 1 omt wms 5 Jan 27 14:54 hola*
> The settings are:
> <confdefs.h>
> #define CONFIGURE_EXTRA_TASK_STACKS 1000000
> ( I tried
> #define CONFIGURE_EXTRA_TASK_STACKS 4000000
> but
> bspstart: Not enough RAM!!!)
> I have overridden the default values:
> /opt/rtems/sparc-rtems/lib/linkcmds
> /* Default values, can be overridden */
> _PROM_SIZE = 8M;
> _RAM_SIZE = 32M;
> I have made 2 trials: First, if I do like this:
> venus:~/TEST3$ tar cvf tarfile Kaffe0.exe Klasses.jar hola
> venus:~/TEST3$ sparc-rtems-ld -r -o tarfile.o -b binary tarfile
> venus:~/TEST3$ /opt/rtems/bin/sparc-rtems-gcc --pipe
> -B/opt/rtems//erc32/lib/ -specs bsp_specs -qrtems -g -Wall -ansi -fasm
> -O4 -mcpu=cypress -c -I/opt/rtems/sparc-rtems/include/ -o
> test.o test.c
> -O4 -mcpu=cypress test.o tarfile.o -o test.exe
> venus:~/TEST3$ /usr/local/erc32/bin/sis -ram 32000 -rom 8000 test.exe
> SIS - SPARC instruction simulator 3.0.5, copyright Jiri Gaisler
> 1995-1998
> Bug-reports to jgais at ws.estec.esa.nl
> serial port A on stdin/stdout
> allocated 32768 K RAM memory
> allocated 8192 K ROM memory
> loading:
> section .text at 0x02000000 (106416 bytes)
> section .data at 0x02019fb0 (3494112 bytes)
> section .bss at 0x0236f090 (22124 bytes)(not loaded)
> sis> run
> IU in error mode (257)
> 16 00000000 00000000 unimp 0
> venus:~/TEST3$ /usr/local/erc32/bin/sparc-rtems-gdb
> test.exe
> GNU gdb 4.17.gnat.3.11p
> Copyright 1998 Free Software Foundation, Inc.
> GDB is free software, covered by the GNU General Public License, and you
> are
> welcome to change it and/or distribute copies of it under certain
> conditions.
> Type "show copying" to see the conditions.
> There is absolutely no warranty for GDB. Type "show warranty" for
> details.
> This GDB was configured as "--host=i686-pc-linux-gnu
> --target=sparc-erc32-elf32"...
> (gdb) tar sim -ram 32000 -rom 8000
> Bug-reports to Jiri Gaisler ESA/ESTEC (jgais at ws.estec.esa.nl)
> Connected to the simulator.
> (gdb) lo
> loading:
> (gdb) bre Init
> Breakpoint 1 at 0x2001238: file test.c, line 70.
> (gdb)
> Note: breakpoint 1 also set at pc 0x2001238.
> Breakpoint 2 at 0x2001238: file test.c, line 70.
> (gdb) n
> Cannot find bounds of current function
> (gdb) run
> Starting program: /home/omt/TEST3/test.exe
> loading:
> Breakpoint 1, Init (argument=0) at test.c:70
> 70 char prueba[5]="rtems";
> 77 status = Untar_FromMemory((unsigned char
> *)(&_binary_tarfile_start), (unsigned long) &_binary_tarfile_size);
> (gdb) n
> assertion "memory" failed: file
> "../../../../../../rtems-19991203.joel/c/src/lib/libc/memfile.c", line
> 340
> Program exited normally.
> rtems-19991203.joel/c/src/lib/libc/memfile.c line 340:
> memory = memfile_alloc_block();
> assert( memory );
> if ( !memory )
> return 1;
> *block_entry_ptr = memory;
> return 0;
> If I only use Klasses.jar
> venus:~/TEST3$ tar cvf tarfile Klasses.jar hola
> -rw-r--r-- 1 omt wms 890880 Feb 11 10:18 tarfile
> -rw-r--r-- 1 omt wms 891360 Feb 11 10:19 tarfile.o
> test.exe
> are
> conditions.
> details.
> (gdb) lo
> loading:
> section .data at 0x02019fb0 (893152 bytes)
> section .bss at 0x020f4090 (22124 bytes)(not loaded)
> (gdb) bre Init
> (gdb)
> Error during write
> Untar_FromMemory (tar_buf=0x201a0e0 "Klasses.jar", size=890880) at
> ../../../../../../rtems-19991203.joel/c/src/libmisc/untar/untar.c:93
> So, the same problem I send you yesterday night by going inside untar:
> 215 for (i=0; i<nblocks; i++)
> (gdb)
> 217 len = ((sizeToGo < 512L)?(sizeToGo):(512L));
> (gdb)
> 218 n = fwrite(&tar_buf[ptr], 1, len, fp);
> (gdb)
> 219 if (n != len)
> (gdb)
> 224 ptr += 512;
> This is a loop
> (gdb) print nblocks
> $118 = 1729
> (gdb) print i
> $119 = 11
> it needs 5 next for i=i+1
> so, I try i=i+1000
> (gdb) next 5000
> Error during write
> I don't know how to solve the problem...
> Thanks for your support,
> Oscar
> Óscar Martínez de la Torre - Office Phone: +31-(0)71.565.5844
> Telecommunication Engineer at Universidad Politécnica de Madrid
> European Space Agency ESTEC/TOS/EMS Erasmus Building Office Nb212
> Keplerlaan,1 - NL 2201 AZ - Noordwijk ZH - The Netherlands
> Mail: omt at wm.estec.esa.nl - Personal Mail: omt at etsit.upm.es
> /* Init
> * This routine is the initialization task for this test program.
> #include <bsp.h>
> #define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
> #define CONFIGURE_TEST_NEEDS_CLOCK_DRIVER
> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> #define CONFIGURE_EXECUTIVE_RAM_SIZE (512*1024)
> #define CONFIGURE_MAXIMUM_SEMAPHORES 20
> #define CONFIGURE_MAXIMUM_TASKS 20
> #define CONFIGURE_INIT_TASK_STACK_SIZE (10*1024)
> #define CONFIGURE_INIT_TASK_PRIORITY 120
> #define CONFIGURE_INIT_TASK_INITIAL_MODES (RTEMS_PREEMPT | \
> RTEMS_NO_TIMESLICE | \
> RTEMS_NO_ASR | \
> RTEMS_INTERRUPT_LEVEL(0))
> rtems_task Init(
> rtems_task_argument argument
> /* configuration information */
> #include <confdefs.h>
> #include <errno.h>
> #include <time.h>
> #include <stdio.h>
> #include <rtems/rtems_bsdnet.h>
> #include <ftpd.h>
> #include <unistd.h>
> #include <rtems/error.h>
> #include <rpc/rpc.h>
> #include <netinet/in.h>
> #include <time.h>
> #include <arpa/inet.h>
> #include <sys/socket.h>
> #include <fcntl.h>
> #include <rtems/untar.h>
> #define PERMS 0666
> extern int _binary_tarfile_start;
> extern int _binary_tarfile_size;
> rtems_task Init(
> rtems_status_code status;
> int fd;
> int fd2;
> int ok;
> char buffer[5];
> printf( "START\n" );
> printf("%s\n",prueba);
> status = Untar_FromMemory((unsigned char *)(&_binary_tarfile_start), (unsigned long) &_binary_tarfile_size);
> fd = open("hola",O_RDWR);
> if (fd==-1)
> printf("problems open: %i\n",fd);
> while ((ok = read(fd, buffer, 4)) >0)
> printf("n:%i leo:%s\n",ok,buffer);
> ok = close(fd);
> if (fd==-1)
> ok=write(fd,prueba,4);
> if (ok==-1)
> printf("problems w1: %i\n",ok);
> ok = close(fd);
> printf("2n:%i leo:%s\n",ok,buffer);
> fd2 = creat("adios",PERMS);
> if (fd2==-1)
> printf("problems creat: %i\n",fd);
> ok=write(fd2,prueba,4);
> if (ok==-1)
> printf("problems w2: %i\n",ok);
> ok=read(fd2,buffer,4);
> if (ok==-1)
> printf("problems r2: %i\n",ok);
> printf("%s\n",buffer);
> exit(0);
janovetz at uiuc.edu | How can it be that mathematics, being after all a
University of Illinois | product of human thought independent of experience,
| is so admirably adapted to the objects of reality?
PP-ASEL | - Albert Einstein
Disclaimer: The policies of this University certainly do not reflect my
own opinions, objectives, or agenda.
