Snapshot 20000104 failed under CygWin 20.1 --- follow-up
Rosimildo daSilva rdasilva at connecttel.com
Mon Jan 10 02:11:42 UTC 2000
>> It returns ENOMEM error, even though the machine has 128M, I've tried to
>> give 8M to the
>> workspace without any luck. :-)
>Is this with a standard test or one of your own?  You have to configure
>a maximum number of keys.  I recall that this is the error when you
>run out of the keys.
Both. When I've got the error, I reconfigured the whole thing with all
tests,
and it I ran psx06 and it failed.
I have debugged with GDB, and it seems that when it is allocating the
buffers for each class, it gets a size that is garbage( a huge value ).
It is easy to recreate:
   + turn ITRON ON
Rosimildo.
