Problems building RTEMS-4.0.0 for MC68332-BSP
    Tobias Kolb
    kolb at iema.uni-stuttgart.de
    Fri Jan 14 17:21:26 UTC 2000
Hi,
I´m new to RTEMS and would appreciate any help on my problem.
I´m trying to build RTEMS-4.0.0 for a BSP derived from the efi332-BSP
which worked fine under RTEMS-3.6 and IMB-AIX (I didn´t do the changes
to make this work and the collegue who did the adaptions is far ...)
I´m trying to build RTEMS-4.0.0 for the MC68332 under Linux.
I´m using the sources from "ftp.OARcorp.com" installing them as
described in "Getting Started with RTEMS for C/C++ Users".
I can build RTEMS using the "bit_rtems" script and the
"CPU_CFLAGS=-m68020" in /rtems-4.0.0/make/custom/efi332.cfg as told for
the efi332-BSP, convert the "hello.exe" sample application to a
srecord-file and load it up on the target. Running the sample
application on the target gives me the following message:
Spurious interrupt: line 1111 Emulation
Vector: 0x0000000b  sp: 0x00f42bc4
Is it right that this means that there is floating-point-opcode which
the MC68332
doesn´t understand?
I tried various compiler switches in /rtems-4.0.0/make/custom/BSP.cfg
like:
-m68020                                ; error message as cited
-m68020 -msoft-float                   ; compiles, program on target
doesn´t start
-m68000 -msoft-float -Wa, -mcpu32      ; compiles, program on target
doesn´t start
Which compiler switches do I have to use to create appropriate code for
my target?
Or is it a totally different problem? I´m really stuck at this point and
would greatly appreciate any help.
Tank you in advance, greetings from Stuttgart
Tobi
Tobias Kolb (Dipl.-Ing.)
Universität Stuttgart
Institut für Elektrische Maschinen und Antriebe
Pfaffenwaldring 47
D-70569 Stuttgart
Tel.  : +49 711 685-7839
Fax   : +49 711 685-7837
www.iema.uni-stuttgart.de
