ip stack mutual exclusion
    Jennifer Averritt
    jennifer at usa.oarcorp.com
    Wed Jan 19 22:19:00 UTC 2000
On Wed, 19 Jan 2000 Fermi at aol.com wrote:
> I am adding a security association database to the
> RTEMS IP-stack to support IPSEC.
> I would like to run RTEMS with a
> thread time slice, but a thread that is acessing the database when its
time quantum expires might leave
> it in an unstable state.
Try:
rtems_task_mode( RTEMS_NO_PREEMPT, RTEMS_PREEMPT_MASK, &pmode);
rtems_task_mode( RTEMS_PREEMPT, RTEMS_PREEMPT_MASK, &pmode);
To protect against an isr you can use:
rtems_interrupt_disable( level );
rtems_interrupt_enable( level );
Jennifer
