compile binutils-2.9.1
Shen,HuiJie
hjshen at utstar.hz.zj.cn
Mon Jan 31 11:38:12 UTC 2000
Hello :
I try to build cross compiler of mpc on NT server.
I installed cywin and do as instruction of RTEMS 19991117 On-Line
Library.
after , it seems OK after doing
/source/binutils-2.9.1/configure --verbose --target=powerpc-rtems \
--prefix=/gcc-powerpc-rtems --with-gnu-as --with-gnu-ld
but when I do
make
it says
gcc -DHAVE_CONFIG_H -I. -I/source/binutils-2.9.1/gas -I. -D_GNU_SOURCE
-I. -I/so
urce/binutils-2.9.1/gas -I../bfd -I/source/binutils-2.9.1/gas/config
-I/source/b
inutils-2.9.1/gas/../include -I/source/binutils-2.9.1/gas/..
-I/source/binutils-
2.9.1/gas/../bfd -g -O2 -c /source/binutils-2.9.1/gas/config/tc-ppc.c
(h:\RTEMS\Cygnus\B19\H-i386-cygwin32\lib\gcc-lib\i386-cygwin32\2.7-B19\cc1.exe
1
054) Exception: STATUS_ACCESS_VIOLATION
1
054) Dumping stack trace to cc1.exe.core
gcc: Internal compiler error: program cc1 got fatal signal 0
make[1]: *** [tc-ppc.o] Error 1
make: *** [all-gas] Error 2
What problem with it.
Help for you support
