Region manager memory allocation
Ryan Bedwell
ra9407 at email.sps.mot.com
Tue Jan 4 16:00:49 UTC 2000
Gentlemen,
Thanks for the discussion. Reducing the page size does solve the
"problem." Perhaps this should be noted in the test's (sp16) docs?
Thanks again,
Ryan
Joel Sherrill wrote:
> Nick.SIMON at syntegra.bt.co.uk wrote:
> > Ryan,
> > Looking at the code a little further down _Heap_Allocate in heap.c, it seems
> > that the allocated pointer is expected to be on a page boundary (& if so,
> > the documentation's not quite right). This means that more memory has to be
> > allocated than might appear necessary. Having said this, however, the
> > consumed size should always be a multiple of page size, which it obviously
> > isn't - your figures show HEAP_BLOCK_USED_OVERHEAD too much has been
> > allocated. Presumably, the blocks get misaligned off the page boundaries
> > too.
> > BTW It looks as if the boundary alignment was a later addition. Does anyone
> > know why it was added? It does make sizing etc much more awkward, and the
> > oversizing may be an attempt to make it easier to decide if a free block is
> > big enough.
> I don't recall it being a later addition. But that was a long time ago.
> > Having said all that, much more saving would be made by reducing page_size.
> > Since RTEMS doesn't use VM, protection & all that stuff, is there any need
> > for page_size to be so big?
> The code in question is simply a test. I thought all the ports set the
> page_size to default to 16 or less for the region used by malloc.
> Usually
> it is 4 or 8 byte boundaries.
> 8 is required on some architectures since malloc'ed items must be
> aligned
> well enough to be doubles.
> > Memory allocation is a bit too important to be (apparently) messed up. If
> > anyone can shed light on this, this, please let us all know.
> Repeating myself, the code in question is simply a test. The large page
> size
> is just testing that a large page size works.
> Other approaches which have been discussed (not implemented) in the past
> include:
> + adding another type of memory allocation scheme which keeps the
> allocation
> information separate from the memory itself (allocate via bitmap or
> something).
> + switch to using the semaphore protected malloc implementation in
> late model
> newlibs. I don't recall whether this was available in 1.8.1 but I
> am pretty
> sure this is available in 1.8.2.
> There are only two heaps/regions used in most RTEMS systems -- executive
> workspace
> and the program heap (malloc). Those have very small page sizes -- 4 or
> 8.
> > -- Nick Simon
> > > -----Original Message-----
> > > From: Ryan Bedwell [mailto:ra9407 at email.sps.mot.com]
> > > Sent: 23 December 1999 16:16
> > > To: rtems-list at oarcorp.com
> > > Subject: Region manager memory allocation
> > > All,
> > > I'm trying to track down a bug I've got in my new BSP with region
> > > manager memory allocation. According to the docs, when a block of
> > > memory is requested from the region manager, that number will
> > > be rounded
> > > up to the nearest page size and allocated (if enough memory is free):
> > > <snip>
> > > "For example, if a request for a 350-byte segment is made in a region
> > > with 256-byte pages, then a 512-byte segment is allocated."
> > > </snip>
> > > However, I'm seeing much larger segments being allocated.
> > > Here's a snip
> > > from a little loop that I wrote. The example uses 128 byte pages and
> > > obtains the actual sizes via calls to rtems_region_get_segment_size():
> > > Request: 64, Grant: 264
> > > Request: 128, Grant: 264
> > > Request: 192, Grant: 392
> > > Request: 256, Grant: 392
> > > Request: 320, Grant: 520
> > > Request: 384, Grant: 520
> > > Request: 448, Grant: 648
> > > Request: 512, Grant: 648
> > > Request: 576, Grant: 776
> > > These numbers seem to make sense with the function _Heap_Allocate (in
> > > heap.c) where the actual work is done ('size' is the requested size):
> > > <snip>
> > > excess = size % the_heap->page_size;
> > > the_size = size + the_heap->page_size + HEAP_BLOCK_USED_OVERHEAD;
> > > if ( excess )
> > > the_size += the_heap->page_size - excess;
> > > if ( the_size < sizeof( Heap_Block ) )
> > > the_size = sizeof( Heap_Block );
> > > </snip>
> > > HEAP_BLOCK_USED_OVERHEAD is 8 bytes on my architecture, so this code
> > > would indicate that for a request of 64,
> > > excess = 64
> > > the_size = 64 + 128 + 8 = 200
> > > the_size += (128 - 64) = 264(!)
> > > What originally clued me in was a problem with test SP16; when an
> > > attempt is made to allocate 3968 bytes from a region that is
> > > 4096 bytes
> > > in length, there is never enough memory to satisfy the request!
> > > Can anyone enlighten?
> > > Thanks,
> > > Ryan
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
