Graphical GDB & BDM?
Thu Jul 13 16:11:42 UTC 2000
Erwin Rol wrote:
> Yeah got it working without a problem.
> I think there is even a entry in the FAQ on how to select a gdb
> when starting ddd.
And you would be correct. :)
http://usa.oarcorp.com/rtems/betas/rtems-4.5.0-beta/online-docs/rtemsdoc-4.5-beta3/share/rtemsdoc/html/FAQ/FAQ00040.html
It goes into detail about building ddd which is not necessary
if you already have ddd installed.
> just check the manual of ddd or your other IDE on how to select
> a gdb.
ddd --debugger TARGET-gdb $1
--joel
> - Erwin
> Asier Santamaria wrote:
> > Hi,
> > This probably isn't the list to ask this question on,
> > but here goes:
> > Has anyone had any luck getting DDD/GDB working with a
> > BDM to MPC823?
> > Or any other graphical GDB application or IDE that
> > works ok with BDM?
> > Regards,
> > Asier Santamaria
> > __________________________________________________
> > Do You Yahoo!?
> > Get Yahoo! Mail - Free email you can access from anywhere!
> > http://mail.yahoo.com/
>         Q - S O F T - E N G I N E E R I N G
>      Rodachtalweg 11, 81549 Muenchen, Germany
> Erwin Rol (Software Engineer)     phone: +49-89-68050051
> Erwin.Rol at Q-Soft-Engineering.com  fax  : +49-89-68050052
