Two questions about Ada programming on rtems
guobing guobing at sohu.com
Tue Jul 18 09:02:08 UTC 2000
Hi,all!Recently I'm using Ada to write a few program which run on rtems.I have two question as follows:
1)Can I use Ada task facility in rtems application?
2)what's relationship between Ada task and rtems task?Is Ada task  mirrorred to rtems task?
Any advice is appreciated.Thanks.
