How to get timezone in RTEMS?
Eric Norum eric at cls.usask.ca
Wed Jul 19 22:00:59 UTC 2000
OUTWATER wrote:
> Hello All:
> I'm trying to get TCL (8.4a) ported to RTEMS and everything compiles except some
> TCL code which tries to determine timezone.
> FYI, the affected files are:
> ./tcl8.4a1/generic/tclClock.c
> and
> /tcl8.4a1/generic/tclUnixTime.c.  "
> timezone" is undeclared and is causing a compile error in both files.
> TCL is configured and compiled using the attached Makefile.rtems-tcl.
> The makefile is placed in ./tcl8.4a1/unix and run using make -f.
> It appears that the code is configured to fallback to a last-ditch method of
> determining timezone and that this method is somehow broken.
> I'm definitely not an expert in Unix time functions (I AM an expert in embedded
> hardware design, though :) ).
> I can hack the two affected source files by declaring timezone to make things
> compile, but this seems inelegant.
> Does anyone have any suggestions on how to attack this and get things working
> properly ?
I don't have tcl8.4, but for tcl8.3 you could avoid the timezone
variable by definining USE_DELTA_FOR_TZ.
Canadian Light Source                      Phone: (306) 966-6308
University of Saskatchewan                 FAX:   (306) 966-6058
Saskatoon, Canada.
