Is there any script-language intepreter avaliable for RTEMS ?
OUTWATER
vac4050 at cae597.rsc.raytheon.com
Thu Jul 20 01:38:28 UTC 2000
Joel -
Here's the stuff you requested:
1. Makefile.rtems-tcl Makefile to build TCL 8.4a1 library for RTEMS. NOTE:
compiles, but not tested yet!
2. README.rtems with simple build instructions
3. tcl8.4a1.patch Simple patch to tcl8.4a1/unix/Makefile.in
Regarding the RTEMS glue for the Intel flash system - did the author ("HongSong Li")
express any willingness to contribute his wrappers for the Intel IVFM code?
Keith
> OUTWATER wrote:
> > For what it's worth, I was able to get the TCL library for version 8.4a1 to
> > compile for an M68K target using the same method that Eric Norum used to get
> > ncurses and readline built (see rtems_packages). Had to hack some time zone
> > stuff, but I wasn'e planning to use time functions anyway.
> > Haven't tried the TCl library to see if it works yet.
> Could you please capture your instructions/notes/comments
> and post them? I would like to include them in the
> contrib directory.
> Eventually (after BSPs are separated from RTEMS proper) we can package
> these things as add-on binaries. :)
> Thanks.
> > Regarding your flash memory file system - can you provide details? Any plans to
> > make the code available?
> I don't know if he answered. It is Intel Flash file system and must be
> used
> with Intel flash only. We may merge his glue but not the Intel code.
> > keith
> > > Hi,
> > > My project needs versatile configuration during startup and dynamicly changing
> > these configurations on-line. Since I've already have flash
> > > memory file system ported to RTEMS, I want to use boot-script file located in
> > FFS to fulfil the requirements. What I need is a script
> > > language intepreter which including variable declaration, macro definition,
> > output redirection, command & parameter parsing and so on.
> > > I've evaluated the monitor of RTEMS, but I think it is too simple to deal with
> > it. Maybe TCL is the best choice but from the release notes of
> > > RTEMS, I found it is not avaliable yet.
> > > Any help is appreciated, thanks in advance !
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
# Makefile for compiling TCL for RTEMS
# Keith Outwater
# Principal Engineer, Raytheon Missile Systems
# vac4050 at cae597.rsc.raytheon.com
# Based entirely on a set of Makefiles developed by Eric Norum for
# compiling GNU readline for RTEMS
# Please feel free to fix or modify this file. I ask only that you
# post any enhancement or corrections to rtems-users at oarcorp.com
# NOTES:
# Right now, libtcl compiles for M68K, but has not been tested. tclsh is not built here.
# Build it separately once the tcl lib is installed.
# Pick up RTEMS configuration
include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
include $(RTEMS_CUSTOM)
include $(PROJECT_ROOT)/make/leaf.cfg
CC += $(CPU_CFLAGS)
# Add dummy RTEMS configuration so that configure scripts work properly.
export LDFLAGS=$(prefix)/$(RTEMS_BSP)/lib/dummy.rel
# For some reason RTEMS Makefiles don't export this
export RANLIB
.PHONY: all
# Include any site-specific options here
all:
./configure \
--host=`uname -m`-$(RTEMS_HOST) \
--prefix=$(prefix) \
--libdir=$(prefix)/$(RTEMS_BSP)/lib \
--includedir=$(prefix)/$(RTEMS_BSP)/lib/include \
--disable-load \
--disable-shared
make "AR=$(AR)" "HOSTCC=gcc" "HOSTCCFLAGS=-I. -I../include " HOSTLDFLAGS="" "CFLAGS+=-DUSE_DELTA_FOR_TZ -DHAVE_TM_ZONE"
make "AR=$(AR)" install
After patching the TCL distribution and copying the files RTEMS.readme
and Makefile.rtems-tcl to tcl8.4a1/unix/, simply run 'make-f makefile.rtems-tcl' in the
./tcl8.4a1/unix directory. Ignore the warnings during installation regarding tclsh.
Desc: tcl8.4a1.patch
URL: <http://lists.rtems.org/pipermail/users/attachments/20000719/ebc60d91/attachment.obj>
