Building i386 on RED Hat
Dmitry Kargapolov dk at gentex.ru
Fri Jul 28 09:57:16 UTC 2000
Friday, July 28, 2000, 12:33:41 PM, you wrote:
ahna> I am unable to get the bit_rtems script to work on a linux Red Hat 6.2 System
ahna> The first issue was the rtems directory which I had to change from rtems-4.5.0-beta3a
ahna> to 4.5.0-beta3a
ahna> After changing the name of the directory I attempted
ahna>     ./bit_rtems i386 i386-rtems
ahna> with a failure in a short period of time
ahna> I then executed
ahna> which when on building for about an hour and a half before it came up with this
ahna> error:
ahna> /opt/rtems/i386-rtems/bin/ld:../../../../../../i386ex/lib/linkcmds:115: parse
ahna> er
ahna> ror
ahna> collect2: ld returned 1 exit status
ahna> make[5]: *** [o-optimize/hello.exe] Error 1
ahna> make[5]: Leaving directory `/opt/rtems/tools/build/i386-rtems/c/i386ex/tests/samples/hello'
ahna> make[4]: *** [all-recursive] Error 1
ahna> make[4]: Leaving directory `/opt/rtems/tools/build/i386-rtems/c/i386ex/tests/samples'
did you have enough space for making? (>1.2Gb)
Sincerely,
Dmitry Kargapolov, ICQ 54000305, dk at gentex.ru
