pbm RTEMS
Mon Jul 31 12:15:16 UTC 2000
I am replying to the list because I am a bit unsure as to
why RPM is mising these files myself.  The normal reason
is that they are not there.  So ..what version/distribution
of Linux are you using?  When you do rpm -qa | grep libc
does libc.so.6 show up?
Your RPM database may not reflect reality on your system.
I think in this case you may have to look into how RPM
is initialized on your machine.
cédric AGNERAY wrote:
> hello,
> I want to install the GNU binutils for RTEMS targetting i386-rtems and I
> have some problems.
> When I do rpm -i rtems-base-binutils-2.9.0.5.24-1.i386.rpm  , it's good.
> But, when I do rpm -i i386-rtems-binutils-2.9.5.0.24-1.i386.rpm , I have
> this error : failed dependencies : ld-linux.so.2 libc.so.6 and libdl.so.2
> are needed by i386-rtems-bin...
> These files are in my /lib path, then I don't understand. Could help me,
> please?
> Cedric
> ________________________________________________________________________
> Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com
