Building RTEMS on Sparc
Frank Szczerba frank at wmi.com
Tue Jun 6 18:02:33 UTC 2000
If you create the directory it is complaining about:
# mkdir /home/akkas/gnu_tools_for_RTEMS/sparc-rtems/sys-include
the build should succeed. It doesn't seem to need any files in that
directory
Frank Szczerba
Development Engineer
Woodward McCoach Inc
frank at wmi.com
-----Original Message-----
To: joel.sherrill at oarcorp.com <joel.sherrill at oarcorp.com>
Cc: rtems-users at oarcorp.com <rtems-users at oarcorp.com>
Date: Tuesday, June 06, 2000 1:00 PM
Subject: Re: Building RTEMS on Sparc
>Hi,
>I am on a sparc machine (SPARC Station 20). What should I do fix
>the problem? Thanks,
>Ahmet Akkas
>Joel Sherrill wrote:
>> Ahmet Akkas wrote:
>> > Hi,
>> > I have the following error message when I run "./bit sparc"
>> > command to able to build the necessary tools for RTEMS.
>> > Could you please tell me what I am missing.
>> What host are you on?  This looks like a known problem on Solaris
>> that is a bug in the gcc fixincludes shell script that the next
>> round of RTEMS gcc patches addresses.
>> > Thanks,
>> > Ahmet Akkas
>> > /bin/sh ./fixinc.sh `pwd`/include
>> > Fixing headers into
>> > /home/akkas/RTEMS_cross_development/tools/build-sparc-tools/gcc/include
for
>> > sparc-unknown-rtems target
>> > ./fixinc.sh: /home/akkas/gnu_tools_for_RTEMS/sparc-rtems/sys-include:
does not
>> > exist
>> > make[1]: *** [stmp-fixinc] Error 1
>> > make[1]: Leaving directory
>> > `/home/akkas/RTEMS_cross_development/tools/build-sparc-tools/gcc'
>> > make: *** [all-gcc] Error 2
>> > ERROR: **** FAILED **** base build (step 1)
>> > Started:   Tue Jun 6 09:32:06 EDT 2000
>> > Finished:  Tue Jun 6 11:15:21 EDT 2000
>> > Directory size information:
>> > 20119   build-sparc-tools
>> > 17816   /home/akkas/gnu_tools_for_RTEMS
>> > The build-sparc-tools subdirectory has NOT been removed.
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel at OARcorp.com                 On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>    Support Available             (256) 722-9985
