Problems building gcc with Cygwin
Palkin Andery support at pi.ccl.ru
Wed Jun 14 05:57:47 UTC 2000
Hello!
I'm trying to install gcc-2.95.2 on winNT (CygWin 20.0).
I'm doing next steps:
   - apply the patch gcc-2.95.2-rtems-20000427.diff.gz
   - Remove directories: - source\egcs-1.1b\libf2c
                         - source\egcs-1.1b\gcc\objc
                         - source\egcs-1.1b\gcc\f
   - link directories: -  ln -s ../newlib-1.8.0/newlib newlib
                       -  ln -s ../newlib-1.8.0/libgloss libgloss
   - configure:
               cd /build/egcs
               /source/gcc-2.95.2/configure --verbose \
                                            --target=m68k-rtems \
                                            --prefix=/gcc-m68k-rtems \
                                            --with-local-prefix=/gcc-m68k-rtems \
                                            --with-gnu-as \
                                            --with-gnu-ld \
                                            --with-newlib
   - install  autoconf package
   - compile by command "make cross" and at this step i am getting error:
for name in _muldi3 _divdi3 _moddi3 _udivdi3 _umoddi3 _negdi2 _lshrdi3 _ashldi3 _ashrdi3
  _ffsdi2 _udiv_w_sdiv _udivmoddi4 _cmpdi2 _ucmpdi2 _floatdidf _floatdisf _fixunsdfsi
  _fixunssfsi _fixunsdfdi _fixdfdi _fixunssfdi _fixsfdi _fixxfdi _fixunsxfdi _floatdixf
  _fixunsxfsi _fixtfdi _fixunstfdi _floatditf __gcc_bcmp _varargs __dummy _eprintf _bb
  _shtab _clear_cache _trampoline __main _exit _ctors _pure; \
do \
  echo ${name}; \
  /build/egcs/gcc/xgcc -B/build/egcs/gcc/ -B/gcc-m68k-rtems/m68k-rtems/bin/
    -I/gcc-m68k-rtems/m68k-rtems/include -O2 -I/source/gcc-2.95.2/gcc/../newlib/libc/sys
     /rtems/include -DCROSS_COMPILE -DIN_GCC     -g -O2 -I./include -g1  -DIN_LIBGCC2
    -D__GCC_FLOAT_NOT_NEEDED -Dinhibit_libc   -I. -I/source/gcc-2.95.2/gcc -I/source
    /gcc-2.95.2/gcc/config -I/source/gcc-2.95.2/gcc/../include -c -DL${name} \
       /source/gcc-2.95.2/gcc/libgcc2.c -o ${name}.o; \
  if [ $? -eq 0 ] ; then true; else exit 1; fi; \
  m68k-rtems-ar rc tmplibgcc2.a ${name}.o; \
  rm -f ${name}.o; \
done
_muldi3
/tmp/ccYSVVk2.s: Assembler messages:
/tmp/ccYSVVk2.s:86: Warning: .type pseudo-op used outside of .def/.endef ignored
/tmp/ccYSVVk2.s:86: Error: Rest of line ignored. First ignored character is `_'.
/tmp/ccYSVVk2.s:112: Warning: .size pseudo-op used outside of .def/.endef ignore
d.
/tmp/ccYSVVk2.s:112: Error: Rest of line ignored. First ignored character is `_'
make[3]: *** [libgcc2.a] Error 1
make[3]: Leaving directory `/build/egcs/gcc'
make[2]: *** [stmp-multilib-sub] Error 2
make[2]: Leaving directory `/build/egcs/gcc'
make[1]: *** [stmp-multilib] Error 1
make[1]: Leaving directory `/build/egcs/gcc'
make: *** [cross] Error 2
Have You got any ideas?
Thanks.
