Help!the problem of buliding GNU CROSS Compiler toolset.
Sat Jun 17 13:03:15 UTC 2000
I would recommend goingo to ftp.oarcorp.com:/pub/rtems/betas and
grab either binaries for your host OR current sources.  Basically
there is an inconsistency in versions.  I think in particular
your newlib is too old but there are other issues as well.
Upgrade to new stuff.  It will be worth it.
Zhou qing guo wrote:
> Hi,
> When I biuld the GNU Cross Compiler Toolset on linux.I do accoeding the
> manul.All is ok.But whaen I run "./bit i386", the error is come: (I hope
> that you could give me a hand)"
>  ../../../../../src/newlib/libc/signal/signal.c: In function `_raise_r':
> ../../../../../src/newlib/libc/signal/signal.c:172: `NSIG' undeclared
> (first use in this function)
> gmake[3]: *** [signal.o] Error 1
> gmake[3]: Leaving directory
> `/home/kinggo/rtems/tools/build-i386-tools/i386-rtems/newlib/libc/signal'
> gmake[2]: *** [signal/lib.a] Error 1
> gmake[2]: Leaving directory
> `/home/kinggo/rtems/tools/build-i386-tools/i386-rtems/newlib/libc'
> gmake[1]: *** [libc/libc.a] Error 2
> gmake[1]: Leaving directory
> `/home/kinggo/rtems/tools/build-i386-tools/i386-rtems/newlib'
> gmake: *** [all-target-newlib] Error 2
> ERROR: **** FAILED **** base build (step 1)
> Started:   Sat Jun 17 13:53:58 CST 2000
> Finished:  Sat Jun 17 14:01:19 CST 2000
> Directory size information:
> 42721   build-i386-tools
> 18      /usr/local/rtems/egcs-1.1b-binutils-2.9.1-newlib-1.8.0/i386-rtems
> The src and build-i386-tools subdirectory have NOT been removed.
