Re-Building RTEMS BSP
William Meadows wmeadows at schaferhsv.com
Tue Jun 20 22:17:12 UTC 2000
What is the standard procedure for building a modified BSP?
I want to change console.c from pc386 BSP and use changes
from Application side.
Is a full re-build of RTEMS necessary?(ie. run ./bit_rtems script with
modified files in path.)
Or how do I build libbsp.a (I guess) alone?
Thanks
wil
