Config i386 build i386ex expects i386-gcc compiler
    John Jeffers
    jjef at inforamp.net
    Mon Jun 26 15:15:09 UTC 2000
Just as a minor bug:
On a clean install of rtems-4.5.0.beta3a the config script calls out
i386-gcc just before going to create makefiles (during the checking for gcc
and that it is a cross compiler).
Build fails.
Copying i386-rtems-gcc to i386-gcc fixed the issue which leads me to
believe that during testing typically there was a i386-gcc cross compiler
in the PATH.
Config should call out the gcc found in the RH Linux pre-prepared RPM.
Cheers John
