Config i386 build i386ex expects i386-gcc compiler
John Jeffers jjef at inforamp.net
Mon Jun 26 15:54:42 UTC 2000
Joel
Sorry My mistake! I typed i386 not i386-rtems for the target
Obviously a user finger problem!  (Sounds like you see this often.)
Thanks John
At 12:28 PM 6/26/2000 Monday, Joel Sherrill wrote:
> > Just as a minor bug:
> > On a clean install of rtems-4.5.0.beta3a the config script calls out
> > i386-gcc just before going to create makefiles (during the checking for gcc
> > and that it is a cross compiler).
>How did you configure RTEMS?  Was the target i386-rtems?
> > Build fails.
> > Copying i386-rtems-gcc to i386-gcc fixed the issue which leads me to
> > believe that during testing typically there was a i386-gcc cross compiler
> > in the PATH.
