A patch for the bit script
Jepsen Hans Peter
hans_peter_jepsen at Danfoss.com
Wed Jun 28 13:26:30 UTC 2000
Hi
The attached patch for the script bit includes three fixes/enhancements:
1. The user.cfg variable BUILD_OTHER_LANGUAGES is now used.
If BUILD_OTHER_LANGUAGES is no,
--enable-languages=c,c++ is added as configure option when building gcc.
2. Before configuration and build of gcc ${INSTALL_POINT}/bin is prepended
to the path.
This fixes a problem I had, where build of gcc or newlib failed, because
it failed to find the ranlib for target.
3. For the two configure- and the two make-commands, it ouputs current
directory and the command used.
E.g.:
BIT: Running in
/export/rtems/rtems-4.5.0-beta/tools/build-m68k-tools:
+ ../binutils-2.10/configure --target=m68k-rtems --verbose
--prefix=/usr/local/rtems/4.5.0-beta
This made it possible for me to track, what the script really does.
The script has only been used under HPUX 10.20 with the command: "./bit
m68k".
SO BEWARE!
Although IMHO it should work under Unix in general.
<<bit.patch.gz>>
Kind regards
Hans Peter
Hans Peter Jepsen Phone: +45 74 88 50 11
Danfoss Drives A/S, Fax: +45 74 65 28 38
DG-253, Ulsnaes 1, Email: Hans_Peter_Jepsen at danfoss.com
DK-6300 Graasten, Denmark or: hpj at computer.org
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20000628/7ab60ee2/attachment.obj>
