A patch for the bit script
Jepsen Hans Peter hans_peter_jepsen at Danfoss.com
Thu Jun 29 06:02:09 UTC 2000
mcollins at hawkeye.sps.mot.com wrote:
> Hans Peter Jepsen wrote:
> > The attached patch for the script bit includes three
> fixes/enhancements:
>   I was unable to access the attachment.  Perhaps you could
> appended it
> as text rather than attach it as an encoded binary.
OK, here it is.
Regards
Hans Peter
*** bit.orig	Tue Jun 20 08:11:43 2000
--- bit	Wed Jun 28 13:13:47 2000
*** 151,159 ****
--- 151,163 ----
      check_fatal $?  "**** FAILED **** unable to make build tree"
      cd ${BUILDDIR}
+     echo BIT: Running in `pwd`:
+     ( set -x
      ../${BINUTILS}/configure --target=${target} \
        --verbose \
        --prefix=${INSTALL_POINT}
      check_fatal $?  "**** FAILED **** unable to configure binutils"
*** 160,166 ****
--- 164,175 ----
      if [ ${do_build} = no ] ; then
        echo "**** SKIPPING BUILD OF BINUTILS  ****"
      else
+       ( set -x
        ${MAKE} all ${MAKE_DOCS} install
        check_fatal $?  "**** FAILED **** unable to build binutils"
      fi
*** 176,188 ****
      cd ${BUILDDIR}
  #  Configure to build the target requested
      ../${GCC}/configure --target=${target} \
        --with-gnu-as --with-gnu-ld --with-newlib --verbose \
!       --prefix=${INSTALL_POINT}
-       # --enable-languages='c c++'
        echo "**** SKIPPING BUILD OF GCC AND NEWLIB ****"
        my_exit 0
--- 185,208 ----
      cd ${BUILDDIR}
+ #  make installed binutils available on PATH
+     PATH=${INSTALL_POINT}/bin:{$PATH}
+     export PATH
+     if [ x${BUILD_OTHER_LANGUAGES} = xno ] ; then
+       LANGUAGE_OPTION=--enable-languages=c,c++
+     fi
+     ( set -x
!       ${LANGUAGE_OPTION} --prefix=${INSTALL_POINT}
        my_exit 0
*** 195,202 ****
      if [ x${CFLAGS_ARG} = x ] ; then
        CFLAGS_ARG="-O2 -g"
      fi
!     echo "BIT: starting base build (step 1)"
      ${MAKE} CC=${GCC_ARG} CFLAGS="${CFLAGS_ARG}" all ${MAKE_DOCS} install
      check_fatal $?  "**** FAILED **** base build (step 1)"
      echo "BIT: completed base build (step 1)"
--- 215,226 ----
        CFLAGS_ARG="-O2 -g"
      fi
!     echo "BIT: starting base build (step 1) in `pwd`:"
!     ( set -x
