ncurses tests
OUTWATER
vac4050 at cae597.rsc.raytheon.com
Thu Jun 1 23:06:25 UTC 2000
Eric - Thanks for the info!
I have been using the examples directory, though, and I'm still running into
problems. I tried the changes suggested in you message, but still no output.
I set up a basic test which also had networking running and I was able to
capture the ncurses log output vi ftp. I based my Init on the Init you placed
in the examples/ncurses directory.
Here it is:
rtems_task Init(
rtems_task_argument argument
rtems_status_code status;
rtems_bsdnet_initialize_network ();
rtems_initialize_ftpd();
status = Untar_FromMemory((unsigned char *)(&_binary_tarfile_start),
&_binary_tarfile_size);
rtems_initialize_webserver();
printf("Start\n");
putchar('1');
putchar('\n');
putc('2', stdout);
putc('\n', stdout);
putenv ("TERM=xterm");
/* putenv ("NCURSES_TRACE=20"); */
trace(TRACE_MAXIMUM);
initscr();
printw("A Test\n");
refresh();
endwin();
printf("End\n");
for (;;){}
status = rtems_task_delete( RTEMS_SELF );
When run, I get
Start
1
2
But nothing in between. Seems like console I/O is working, just not for ncurses.
I've attached the ncurses log if you're interested...
BTW, I'm using kermit on an HP workstation as my emulator (kermit is run in an
xterm). I wonder if taht's the problem...
keith
> One reason for sure that you'll not see any output from the tests linked
> against dummy.rel is that there's no TERM environment variable. Also,
> the tests provide a main function which conflicts with the RTEMS main
> function.
> The build procedure for the ncurses package was not intended to create
> working tests. Only the programs in the examples directory should be
> expected to work.
> When I compiled the tests with -Dmain=rtems_main and used the following
> Init routine I was able to run the curses tests I tried.
> void
> Init (rtems_task_argument ignored)
> static char *argv[] = {
> "test",
> NULL
> rtems_main (1, argv);
> Eric Norum eric at cls.usask.ca
> Canadian Light Source Phone: (306) 966-6308
> University of Saskatchewan FAX: (306) 966-6058
> Saskatoon, Canada.
Desc: trace
URL: <http://lists.rtems.org/pipermail/users/attachments/20000601/51d73e60/attachment-0001.obj>
