ncurses tests
Eric Norum
eric at cls.usask.ca
Fri Jun 2 17:11:16 UTC 2000
Charles-Antoine Gauthier wrote:
> Is this the 16-bit baud rate problem that was reported before?
> FYI, in many console device drivers, the baud rate is represented as a
> signed 16 bit integer. You can't do more than 32767 bps. This should be
> fixed if it hasn't.
32-bit value in 68360 console driver.
But here's the problem that OUTWATER <vac4050 at cae597.rsc.raytheon.com>
has reported:
The initial open of a device sets the speed in the termios structure to
9600 baud -- see rtems_termios_open. The smc1Initialize routine doesn't
use this (???) so the rate stays at the 115.2 kbaud (as OUTWATER has
configured) for `normal' operation. When curses starts, it does an
ioctl to get the termios state, sets non-cooked mode and does an ioctl
to set the state -- and ends up changing the rate to 9600 baud.
Now, where's the bug? Should the smc1Initialize abide by the termios
speed? Probably. But then how would anyone get a power-up serial line
rate of anything other than 9600 baud? I'd say that there's some
configuration information missing on startup -- but where to put it?
Eric Norum eric at cls.usask.ca
Canadian Light Source Phone: (306) 966-6308
University of Saskatchewan FAX: (306) 966-6058
Saskatoon, Canada.
