GDB-BDM erratic phenomenon
Kim, Jeong-Hwan
frog at lgic.co.kr
Wed Jun 7 14:47:41 UTC 2000
CPU is MC68360 and gdb patch is gdb_4.18_bdm.
The wrong operation of my bdm board may result from just my soldering mistake,
not schematic problem.
I used RESETS instead of RESETH.
Does it affect the operation of BDM ?
Not connecting Vcc to the bdm board, I ran chk program ((ex) chk /dev/bdm0).
The check program wrote and read the Address registers, Data registers and
it converted PC to 0.
I seemed that the check program read and wrote reigsters correctly.
( For each register "..........................." was displayed and no error message )
But I'm not sure it operates normally - because when I connect Vcc to my bdm board
it returns errors and when I ran executable files with gdb its result was not good.
-----원본 메시지-----
보낸 사람: Erwin Rol <Q-Soft-Eng at t-online.de>
받는 사람: Kim <Kim>; Jeong-Hwan <frog at cosmos.lgic.co.kr>
참조: rtems-users at oarcorp.com <rtems-users at oarcorp.com>
날짜: 2000년 6월 7일 수요일 오후 8:14
제목: Re: GDB-BDM erratic phenomenon
From Q-Soft-Eng at t-online.de Wed Jun 7 20:09:53 2000
Return-Path: <Q-Soft-Eng at t-online.de>
Received: from ns.lgic.co.kr ([210.112.199.131]) by cosmos.lgic.co.kr (88.8/8.8.8) with ESMTP id UAA11730 for <frog at lgic.co.kr>; Wed, 7 Jun 2000 20:09:52 +0900 (KST)
Received: from mailout05.sul.t-online.com (mailout05.sul.t-online.com [194.25.134.82])
by ns.lgic.co.kr (8.9.3/8.9.3) with ESMTP id UAA10227
for <frog at lgic.co.kr>; Wed, 7 Jun 2000 20:11:02 +0900 (KST)
Received: from fwd07.sul.t-online.de
by mailout05.sul.t-online.com with smtp
id 12zdie-0005QF-01; Wed, 7 Jun 2000 13:09:56 +0200
Received: from LINUX.Q-Soft-Engineering.com (320094152587-0001@[62.155.143.202]) by fwd07.sul.t-online.de
with esmtp id 12zdiP-0Qv8roC; Wed, 7 Jun 2000 13:09:41 +0200
Received: from q-soft-engineering.com (erwin [192.168.10.20])
by LINUX.Q-Soft-Engineering.com (8.9.3/8.9.3) with ESMTP id NAA12223;
Wed, 7 Jun 2000 13:14:10 +0200
Message-ID: <393E2EAA.C12B50CA at q-soft-engineering.com>
Date: Wed, 07 Jun 2000 13:14:50 +0200
Reply-To: Erwin.Rol at q-soft-engineering.com
Organization: Q-SOFT Engineering GmbH & Co. KG
X-Mailer: Mozilla 4.72 [en] (WinNT; U)
X-Accept-Language: en
MIME-Version: 1.0
To: "Kim, Jeong-Hwan" <frog at lgic.co.kr>
CC: rtems-users at oarcorp.com
Subject: Re: GDB-BDM erratic phenomenon
References: <002301bfd067$db41e180$dd3d9696 at JHwan_K.lgic.co.kr>
Content-Type: text/plain; charset=us-ascii
Content-Transfer-Encoding: 7bit
X-Sender: 320094152587-0001 at t-dialin.net
What CPU, and which board ?
If you are talking about Frank Przybylski's board you might
check his web site because there where some small problems
with it, also look in the mailing list archive for a mail
from me of a convo i had with Frank.
- Erwin
"Kim, Jeong-Hwan" wrote:
> Hi, everyone
> I have made a gdb-bdm board following a public schematic.
> However, I found an erratic situation.
> When Vcc is connected to the board, the error occurs,
> but when Vcc is disconnected from the bdm board it operates normally.
> Does anybody see such a pheonomenon?
Q - S O F T - E N G I N E E R I N G
Rodachtalweg 11, 81549 Muenchen, Germany
Erwin Rol (Software Engineer) phone: +49-89-68050051
Erwin.Rol at Q-Soft-Engineering.com fax : +49-89-68050052
