Mismatched _Thread_Enable_dispatch and _Thread_Disable_dispatch
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Jun 7 15:44:17 UTC 2000
Charles-Antoine Gauthier wrote:
> In
> rtems/c/src/exec/score/src/objectget.c(_Objects_Get) and
> rtems/c/src/exec/score/src/objectgetbyindex.c(_Objects_Get_by_index),
> there is no matching _Thread_Enable_dispatch() to the
> _Thread_Disable_dispatch() when an object pointer is returned.
> I am thinking that this might be a explicit design decision rather than
> an oversight and that you intended the caller to re-enable dispatching.
> In this way, the caller is guaranteed that the returned pointer points
> to an existing object until the caller re-enables dispatching (or
> deletes the object itself). Unfortunately, this is not documented.
> Was that the intent or is this a bug? I wont "fix it" if the code is
> "correct", I will just add the _Thread_Enable_dispatch() in the right
> places.
It is a VERY deliberate design decision. When _Objects_Get* returns
an object pointer, you are ensured that dispatching is disabled.
If you look at RTEMS services, you will generally see this pattern:
error check parameters
the_XXX = _XXX_Get( id, &location ); /* wrapper for _Objects_Get */
switch ( location ) {
case OBJECTS_REMOTE:
make remote call
case OBJECTS_ERROR:
return invalid id error
case OBJECTS_LOCAL:
any error checks that require the_XXX object pointer to make
do operation on the_XXX object.
_Thread_Enable_dispatch();
return successful status
> I found out about this issue the hard way. I attempted to use
> _Object_Get_by_index() to get the object id of ITRON tasks given only
> their index. I looked up three tasks and ended up in my main task with
> _Thread_Dispatch_disable_level set to 3!
:) And that totally hosed the system I am sure. :)
> I then looked for all threads (of all types) using _Object_Get_next().
> That got me into trouble also. (I will try using
> rtems_monitor_manager_next() directly rather than roll my own now that I
> found out that this function exists).
Good idea.
> The point of the exercise is to push all thread stacks onto the marking
> stack of the Boehm Garbage Collector. To do this, we need to find all
> threads, and then find their stacks and stack pointers. As you can see,
> we are trying to get the last bit of the gcj/libgcj technology ported to
> RTEMS.
I think there is a loop in the monitor code to cycle over all tasks.
Definitely there is one in the usage report generator in the stack
checker.
What about a "create" user extension that marks the stack? Don't you
need to mark new tasks as well?
> P.S. What about CVS access to RTEMS?
That one is for Mark to answer. Ask mark.johannes at OARcorp.com. :)
> Institute for Information Technology Institut de technologie de
> l'information
> National Research Council of Canada Conseil national de recherches du
> Canada
joel at OARcorp.com On-Line Applications Research
