GDB-BDM erratic phenomenon
Erwin Rol
Q-Soft-Eng at t-online.de
Wed Jun 7 16:08:32 UTC 2000
Sorry can't help you with the 68360, i only have
it running on a MPC860, and there are some differences i believe.
Checking the list archive might turn up some usefull info though.
- Erwin
"Kim, Jeong-Hwan" wrote:
> CPU is MC68360 and gdb patch is gdb_4.18_bdm.
> The wrong operation of my bdm board may result from just my soldering mistake,
> not schematic problem.
> I used RESETS instead of RESETH.
> Does it affect the operation of BDM ?
> Not connecting Vcc to the bdm board, I ran chk program ((ex) chk /dev/bdm0).
> The check program wrote and read the Address registers, Data registers and
> it converted PC to 0.
> I seemed that the check program read and wrote reigsters correctly.
> ( For each register "..........................." was displayed and no error message )
> But I'm not sure it operates normally - because when I connect Vcc to my bdm board
> it returns errors and when I ran executable files with gdb its result was not good.
> -----¿øº» ¸Þ½ÃÁö-----
> º¸³½ »ç¶÷: Erwin Rol <Q-Soft-Eng at t-online.de>
> ¹Þ´Â »ç¶÷: Kim <Kim>; Jeong-Hwan <frog at cosmos.lgic.co.kr>
> ÂüÁ¶: rtems-users at oarcorp.com <rtems-users at oarcorp.com>
> ³¯Â¥: 2000³â 6¿ù 7ÀÏ ¼ö¿äÀÏ ¿ÀÈÄ 8:14
> Á¦¸ñ: Re: GDB-BDM erratic phenomenon
> >From Q-Soft-Eng at t-online.de Wed Jun 7 20:09:53 2000
> Return-Path: <Q-Soft-Eng at t-online.de>
> Received: from ns.lgic.co.kr ([210.112.199.131]) by cosmos.lgic.co.kr (88.8/8.8.8) with ESMTP id UAA11730 for <frog at lgic.co.kr>; Wed, 7 Jun 2000 20:09:52 +0900 (KST)
> Received: from mailout05.sul.t-online.com (mailout05.sul.t-online.com [194.25.134.82])
> by ns.lgic.co.kr (8.9.3/8.9.3) with ESMTP id UAA10227
> for <frog at lgic.co.kr>; Wed, 7 Jun 2000 20:11:02 +0900 (KST)
> Received: from fwd07.sul.t-online.de
> by mailout05.sul.t-online.com with smtp
> id 12zdie-0005QF-01; Wed, 7 Jun 2000 13:09:56 +0200
> Received: from LINUX.Q-Soft-Engineering.com (320094152587-0001@[62.155.143.202]) by fwd07.sul.t-online.de
> with esmtp id 12zdiP-0Qv8roC; Wed, 7 Jun 2000 13:09:41 +0200
> Received: from q-soft-engineering.com (erwin [192.168.10.20])
> by LINUX.Q-Soft-Engineering.com (8.9.3/8.9.3) with ESMTP id NAA12223;
> Wed, 7 Jun 2000 13:14:10 +0200
> Message-ID: <393E2EAA.C12B50CA at q-soft-engineering.com>
> Date: Wed, 07 Jun 2000 13:14:50 +0200
> From: Q-Soft-Eng at t-online.de (Erwin Rol)
> Reply-To: Erwin.Rol at q-soft-engineering.com
> Organization: Q-SOFT Engineering GmbH & Co. KG
> X-Mailer: Mozilla 4.72 [en] (WinNT; U)
> X-Accept-Language: en
> MIME-Version: 1.0
> To: "Kim, Jeong-Hwan" <frog at lgic.co.kr>
> CC: rtems-users at oarcorp.com
> Subject: Re: GDB-BDM erratic phenomenon
> References: <002301bfd067$db41e180$dd3d9696 at JHwan_K.lgic.co.kr>
> Content-Type: text/plain; charset=us-ascii
> Content-Transfer-Encoding: 7bit
> X-Sender: 320094152587-0001 at t-dialin.net
> What CPU, and which board ?
> If you are talking about Frank Przybylski's board you might
> check his web site because there where some small problems
> with it, also look in the mailing list archive for a mail
> from me of a convo i had with Frank.
> - Erwin
> > Hi, everyone
> > I have made a gdb-bdm board following a public schematic.
> > However, I found an erratic situation.
> > When Vcc is connected to the board, the error occurs,
> > but when Vcc is disconnected from the bdm board it operates normally.
> > Does anybody see such a pheonomenon?
> Q - S O F T - E N G I N E E R I N G
> Rodachtalweg 11, 81549 Muenchen, Germany
> Erwin Rol (Software Engineer) phone: +49-89-68050051
> Erwin.Rol at Q-Soft-Engineering.com fax : +49-89-68050052
