Problem about building the cross Compiler Toolset(i386)
Zhou qing guo zhouqg at lzu.edu.cn
Sun Jun 18 14:01:04 UTC 2000
Dear James,
     Thanks for your help.
On Sun, 18 Jun 2000, James Housley wrote:
> Zhou qing guo wrote:
> > Hi,Could you help me? I meet the problem again when I again bulid the
> > cross complier toolset on x86 pc running Linux.I did like this:
> > Unarchiving the tools(it's ok),Broken install Program(it's ok),Apply RTEMS
> > Patch to EGCS,binutils,newlib(it's ok).Localizing the Configuration(just
> > set INSTALL_POINT=/usr/local/rtems;BUILD_DOCS=yes;ENABLE_RTEMS_TESTS=yes),
> > But Running the bit Script:#./bit i386,this time the error is:
> > "install:  cpp.info* does not exist
> > install:  gcc.info* does not exist
> > gmake[1]: *** [install-info] Error 1
> > gmake[1]: Leaving directory
> > `/home/kinggo/rtems/tools/build-i386-tools/gcc'
> > gmake: *** [install-gcc] Error 2
> > ERROR: **** FAILED **** base build (step 1)
> Are you using the newest versions?
Because of the speed of dowloading,I still have not downloaded the newest
version.
> There are both a beta3a version in
> the ftp://ftp.oarcorp.com/pub/rtems/betas/rtems-4.5.0-beta/source
> directory and in the ftp://ftp.oarcorp.com/pub/rtems/snapshots/current/
> dir a newer snapshot.  There are also precompiled Linux PRMs in the
> ftp://ftp.oarcorp.com/pub/rtems/betas/rtems-4.5.0-beta/c_tools/linux_x86/index.html.
> Was "cpp.info does not exist" your first error?
Yes,it's the first error.
> Or did also complian
> much earlier about makeinfo not existing?
No.I hope that you could give me more advice.
Thanks again!
Yours
Kinggo
