Storing an array
Jorge Andreu García
andreu at robot3.cps.unizar.es
Mon Jun 19 11:18:53 UTC 2000
Nick.SIMON at syntegra.bt.co.uk wrote:
> > -----Original Message-----
> > From: Jorge Andreu Garca [mailto:andreu at robot3.cps.unizar.es]
> > Sent: 19 June 2000 09:11
> > To: rtems
> > Subject: Storing an array
> > Hello:
> > I want to use an array of 120.000 integersin a program that
> > should run
> > on rtems, but I can't:
> > When I store this in memory, the program stop when it read the
> > declaration line of the array.
> If your program is executing a declaration it must be an automatic, i.e. on
> the stack. I doubt you have 480K bytes of stack space available!
How much space has the stack more or less? Can I enlarge this size?
> > When I store it in heap (with a pointer
> > in Ada) the computer reboot in the same line.
> Putting it on the heap is probably the right thing - assuming you have
> enough space in your heap.
how can I check if I have enough place?
> If you have (or should have) it could be that your heap has become
> corrupted.
> The other valid way to store a large object is as a static or global, if
> it's something thats needed continuously, or over & over again, in your
> application.
Where is stored a global array?
> > Is there any function of rtems or any specification file where I can
> > change the maximum size of the variables?
> This is done in the BSP. Which are you using?
I am running my RTEMS program in a Pentium II, so I use the i386-rtems BSP
> BTW do you really need 120
> thousand integers? It does seem a lot.
The program is used to control an autonomous robot at low-level. I have to
store all the velocities of both wheel during a second (1 measure per
milisecond). So I use a 60000 elements vector where each element store the
velocity of both wheels. So I have 120000 of floats (not integer I realize)
JORGE
