Byte-order problems with GDB and BDM driver
Chris Johns cjohns at cybertec.com.au
Wed Jun 21 12:43:25 UTC 2000
Dario Alcocer wrote:
> I've got more information regarding the byte-ordering problem using
> the BDM interface with gdb.  As per Chris John's suggestion, I
> downloaded gdb-5.0 and patched it using the latest BDM patch.  I still
> get the byte-ordering problems.
> However, it now appears that there's something *definitely* wrong with
> how bdmReadMemory() works, at least with my Coldfire setup using the
> P&E Coldfire pod.
I think you are correct, something is wrong. I am currently not sure
what it is.
> First, here's a run that exhibits the problem:
>     $ /opt/rtems/gdb/bin/m68k-bdm-elf-gdb hello.exe
>     GNU gdb 5.0
>     Copyright 2000 Free Software Foundation, Inc.
>     GDB is free software, covered by the GNU General Public License, and you are
>     welcome to change it and/or distribute copies of it under certain conditions.
>     Type "show copying" to see the conditions.
>     There is absolutely no warranty for GDB.  Type "show warranty" for
>     details.
>     This GDB was configured as "--host=i686-pc-linux-gnu --target=m68k-bdm-elf"...
>     (gdb) load
>     (gdb) bdm_setdebug 1
>     (gdb) x/16bx 0x20000
>     BDM: Read 00 @  0x20000
>     BDM: Read 00 @  0x20001
>     BDM: Read 00 @  0x20002
>     BDM: Read 00 @  0x20003
>     BDM: Read 00 @  0x20004
>     BDM: Read 0x7c @  0x20005
>     BDM: Read 00 @  0x20006
>     BDM: Read 0x03 @  0x20007
>     0x20000:    0x00    0x00    0x00    0x00    0x00    0x7c    0x00
>     0x03
>     BDM: Read 0x2e @  0x20008
>     BDM: Read 0x30 @  0x20009
>     BDM: Read 0x4e @  0x2000a
>     BDM: Read 0xf9 @  0x2000b
>     BDM: Read 0x34 @  0x2000c
>     BDM: Read 0x02 @  0x2000d
>     BDM: Read 0x0c @  0x2000e
>     BDM: Read 0x70 @  0x2000f
>     0x20008 <start+4>:  0x2e    0x30    0x4e    0xf9    0x34    0x02
>     0x0c
>     0x70
>     (gdb) q
>     BDM: Status 0x2
On a 5206e and a P&E pod I get :
$ m68k-bdm-elf-gdb sfp.elf
GNU gdb 5.0
are
conditions.
details.
BDM: Read 0x26 @  0x20000
BDM: Read 0x2e @  0x20001
BDM: Read 0x08 @  0x20003
BDM: Read 0x24 @  0x20004
BDM: Read 0x2e @  0x20005
BDM: Read 0x0c @  0x20007
0x20000:        0x26    0x2e    0x00    0x08    0x24    0x2e    0x00
0x0c
BDM: Read 0x4a @  0x20008
BDM: Read 0xb9 @  0x20009
BDM: Read 00 @  0x2000a
BDM: Read 0x14 @  0x2000b
BDM: Read 0xb8 @  0x2000c
BDM: Read 00 @  0x2000d
BDM: Read 0x66 @  0x2000e
BDM: Read 0x10 @  0x2000f
0x20008:        0x4a    0xb9    0x00    0x14    0xb8    0x00    0x66
0x10
(gdb) q
BDM: Status 0x4
BDM: Go
> The bytes above are *incorrect*; the correct byte sequence is:
>     20000:       0000 0000
>     20004:       2e7c 0003
>     20008:       3430 4ef9
>     2000c:       0002 0c70
> However, if I perform a short read *before* I attempt the byte read, I
> get the correct result:
>     GNU gdb 5.0
>     details.
>     (gdb) load
>     (gdb) x/4hx 0x20000
>     BDM: Read 0000 @  0x20000
>     BDM: Read 0000 @  0x20002
>     BDM: Read 0x2e7c @  0x20004
>     BDM: Read 0x0003 @  0x20006
>     0x20000:    0x0000  0x0000  0x2e7c  0x0003
>     (gdb) x/8bx 0x20000
>     BDM: Read 0x2e @  0x20004
>     0x20000:    0x00    0x00    0x00    0x00    0x2e    0x7c    0x00
>     0x03
>     (gdb) q
>     BDM: Status 0
GNU gdb 5.0
are
conditions.
details.
(gdb) x/4hx 0x20000
BDM: Read 0x262e @  0x20000
BDM: Read 0x0008 @  0x20002
BDM: Read 0x242e @  0x20004
BDM: Read 0x000c @  0x20006
0x20000:        0x262e  0x0008  0x242e  0x000c
(gdb) x/8bx 0x20000
0x0c
(gdb) q
BDM: Status 0x4
BDM: Go
> Notice how both the short and byte reads yield the correct results.
Yes. I will need to look at this more. I will try and modify the `chk'
program to try and generate the problem.
> Any ideas why the order of short and byte reads would be significant?
I will try the same target 5307 target as you tomorrow and see what get.
 Chris Johns, mailto:cjohns at cybertec.com.au mailto:ccj at acm.org
