Building RTEMS BSP???
jennifer averett jennifer.averett at oarcorp.com
Wed Jun 21 18:26:48 UTC 2000
You may want to read "RTEMS BSP and Device Driver Development Guide".
If you only wish to customize the console driver, you can override
console.c
in your application (just make sure all methods are defined).
Jennifer
William Meadows wrote:
> I'm re-submitting this on the fluke that the previous subject heading
> "Re-Building RTEMS BSP" caused skippage from you all :) Hopefully,
> everyone just thought I was being replied to! Thanks in advance.
> Previous Message:
> What is the standard procedure for building a modified BSP?
> I want to change console.c from pc386 BSP and use changes
> from Application side.
> Is a full re-build of RTEMS necessary?(ie. run ./bit_rtems script with
> modified files in path.)
> Or how do I build libbsp.a (I guess) alone?
> Thanks
> wil
