Config i386 build i386ex expects i386-gcc compiler
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Jun 26 16:28:00 UTC 2000
John Jeffers wrote:
> Just as a minor bug:
> On a clean install of rtems-4.5.0.beta3a the config script calls out
> i386-gcc just before going to create makefiles (during the checking for gcc
> and that it is a cross compiler).
How did you configure RTEMS? Was the target i386-rtems?
> Build fails.
> Copying i386-rtems-gcc to i386-gcc fixed the issue which leads me to
> believe that during testing typically there was a i386-gcc cross compiler
> in the PATH.
> Config should call out the gcc found in the RH Linux pre-prepared RPM.
> Cheers John
joel at OARcorp.com On-Line Applications Research
