gdb stub for 68360
Andrew Bythell
abythell at nortelnetworks.com
Wed Mar 1 21:48:36 UTC 2000
Gus Palone wrote:
> > I have finally got a gdb monitor going on a 68360 target (needs some
> > cleaning) and I can connect to it with gdb over a serial line.
...then you sound like someone who can help me with this problem (though
I hope anyone will feel free to respond!). I'm not sure if the problem
is with my stub or with my build of gdb.
The Problem:
I startup my target and it issues the packet $S07#ba , which gdb
receives and is happy. But then gdb starts issuing commands that the
m68k-stub doesn't support, like $qOffsets#4b and $Hc-1#09. If I
manually issue these commands, the target returns +$#00$#00.
The Question
Do I need to add support for these commands to my stub, or do I need to
modify gdb to send different commands? Alternatively, does anyone have
proven source code for a 68360 stub that they would be willing to post?
The Setup
My original m68k-stub.c had the CVS tag Header: remcom.c,v 1.34 91/03/09
12:29:49 glenne Exp $
and I am using gdb 4.17 configured as "--host=i586-pc-linux-gnu
--target=m68k-rtems" with the appropriate rtems patch applied.
Any input is appreciated,
A.
Andrew Bythell System Verification
Nortel Networks Microelectronics Group
Ottawa, Ontario Canada esn.39.56930
tel.613.765-6930 fax.613.763-7795
