GDB patch for 167Bug
Charles-Antoine Gauthier
charles.gauthier at nrc.ca
Mon Mar 6 21:37:43 UTC 2000
Attached is a patch to allow GDB 4.18 to write to the MVME167 through
167Bug. The MS command does not work. The MW command must be used.
Institute for Information Technology Institut de technologie de
l'information
National Research Council of Canada Conseil national de recherches du
Canada
*** gdb-4.18/gdb/167bug-rom.c Mon Mar 6 14:20:50 2000
--- ../gdb/gdb/167bug-rom.c Mon Mar 6 14:54:42 2000
*** 110,118 ****
m167bug_cmds.clr_break = "nobr %x\r"; /* clear a breakpoint */
m167bug_cmds.clr_all_break = "nobr\r"; /* clear all breakpoints */
m167bug_cmds.fill = "bf %x:%x %x;b\r"; /* fill (start count val) */
! m167bug_cmds.setmem.cmdb = "ms %x %02x\r"; /* setmem.cmdb (addr, value) */
! m167bug_cmds.setmem.cmdw = "ms %x %04x\r"; /* setmem.cmdw (addr, value) */
! m167bug_cmds.setmem.cmdl = "ms %x %08x\r"; /* setmem.cmdl (addr, value) */
m167bug_cmds.setmem.cmdll = NULL; /* setmem.cmdll (addr, value) */
m167bug_cmds.setmem.resp_delim = NULL; /* setreg.resp_delim */
m167bug_cmds.setmem.term = NULL; /* setreg.term */
--- 110,118 ----
! m167bug_cmds.setmem.cmdb = "mw %x %02x;b\r"; /* setmem.cmdb (addr, value) */
! m167bug_cmds.setmem.cmdw = "mw %x %04x;w\r"; /* setmem.cmdw (addr, value) */
! m167bug_cmds.setmem.cmdl = "mw %x %08x;l\r"; /* setmem.cmdl (addr, value) */
*** gdb-4.18/gdb/ChangeLog Mon Mar 6 15:38:40 2000
--- ../gdb/gdb/ChangeLog Mon Mar 6 16:33:39 2000
*** 1,3 ****
--- 1,7 ----
+ 2000-03-06 Charles-Antoine Gauthier <charles.gauthier at nrc.ca>
+ * 167bug-rom.c(init_m167bug_cmds): Change the write commands.
Fri Aug 6 165:41:15 EDT 1999 Charles-A. Gauthier <charles.gauthier at iit.nrc.ca>
* config/m68k/monitor.mt (TDEPFILES): Add 167bug-rom.o.
