mvme167 patch for rtems-4.5.0-beta1c
Charles-Antoine Gauthier charles.gauthier at nrc.ca
Wed Mar 8 22:31:34 UTC 2000
Partially. Thanks. I have taken the habit of using -ko a lot with CVS.
What I mostly had in mind is the result of doing a bootstrap. For some
reason, all my rtems/aclocal/*.m4 files have joel's id in them. When I
bootstrap, the generated aclocal.m4 files get my id. This doesn't sound
right. Why are the macros not copied without fiddling of the id strings?
"John M. Mills" wrote:
> On Wed, 8 Mar 2000, Charles-Antoine Gauthier wrote:
> > Now if we could just deal with those annoying ID strings... Any way to
> > bootstrap without having my name appear in the files? It generates too
> > many false diffs.
> I run diffs between exported, rather than checked-out  source trees, so I
> do something like:
> % cvs -d $OAR_CVSROOT export -kk -D "<date_string>" rtems \
>   -d <desired_path1>
> and similarly for the working tree into <desired_path2>. Then from just
> above them:
> % diff -u -r -N <desired_path1> <desired_path2> > <desired_diff_filename>
> I now have a pretty clean patch set which may be applied back against a
> normal, checked-out source tree. Most keywords are reduced to their
> tokens:
> /* $Id$ */
> etc.
> I don't know if that's what you were looking for.
>   John Mills, Sr. Software Engineer
>   TGA Technologies, Inc.
>   100 Pinnacle Way, Suite 140
>   Norcross, GA 30071-3633
>   e-mail: jmills at tga.com
>   Phone: 770-441-2100 ext.124 (voice)
>          770-449-7740 (FAX)
Institute for Information Technology   Institut de technologie de
l'information
National Research Council of Canada    Conseil national de recherches du
Canada
