ttcp promblem in my 68360 board
Park, Chan Taek
urinara at www.ati.co.kr
Wed Mar 15 01:40:09 UTC 2000
The network driver in the 4.5.0 beta release had been tested successfully on my
target board.
There is no problem in the ttcp with short buflen.
Also the web server had been tested successfully and URL is as follows.
http://203.248.186.108/index.html
Thank you very much.
Eric Norum wrote:
> "Park, Chan Taek" wrote:
> > Hello, rtems-users!
> > > > Hello, rtems-list users!
> > > > I'm now benchmarking the ttcp for my 68360 board's ethernet performance.
> > > > There is no problem when I set the buflen to 8K bytes(this is default in
> > > > the ttcp source code) or more than 512 bytes.
> > > > In this case the ttcp transmits 16M bytes successfully from my target
> > > > board to PC(winnt & cygwin) and vice versa.
> > > > And when the ttcp finished it prints out statistics information about
> > > > TCP throughput.
> > > > But when I set the buflen to small such as 100 bytes with -l option, the
> > > > ttcp never completed.
> > > > It was blocked forever by the write function after some number of calls
> > > > to the write function.
> > > > My board configurations and host environments are that:
> > > > Target
> > > > MC68EN360 33MHz Rev.C
> > > > 16MB DRAM
> > > > SCC1 for ethernet(10Mbps)
> > > > SMC1 for console(38.4kbps)
> > > > Host
> > > > Windows NT 4.0
> > > > Cygwin32 B20.1
> > > > egcs-1.1b.tar.bz2
> > > > binutils-2.9.1.tar.gz
> > > > newlib-1.8.0.tar.gz
> > > > egcs-1.1b-rtems-diff-19981028.gz
> > > > binutils-2.9.1-rtems-diff-19981027.gz
> > > > newlib-1.8.0-rtems-diff-19981027.gz
> > > > rtems-4.0.0.tgz
> > > > Please help me for that problem.
> > > 1) There have been lots of changes made since 4.0.0. Perhaps that will
> > > fix your problem.
> > First, I'm sorry for my bad english!
> > There is same problem in the current version of rtems, 20000118a.
> > I'm working within Redhat 6.0.
> This has been fixed for the 68360 in the 4.5.0 beta release.
> The problem is present in all network drivers which use scatter/gather
> DMA. As far as I know, the problem has been fixed only in the 68360
> driver.
> Joel has a list of drivers which need to be fixed.
> Eric Norum eric at cls.usask.ca
> Canadian Light Source Phone: (306) 966-6308
> University of Saskatchewan FAX: (306) 966-6058
> Saskatoon, Canada.
