How to build flash image for MPC860 ?
Li HongSong
hsli at utstar.hz.zj.cn
Mon Mar 27 04:55:45 UTC 2000
Hi,
I have problem building flash image for Motorola FADS860
evaluation board.
The BSP is derived from eth_comm, I modified start.S to
add some initialization code for FADS860 board and relocated it
at section .entry which load address start at flash reset vector.
I also modified linkcmds which listed below to locate all
sections in dram except the section .entry. In the end of start.S,
it will copy the .text, .data and .vectors from flash to dram.
But when I finished building samples based on this BSP and program
the image to flash memory using mpc8bug software, I find only the
section .entry is programmed to flash, all other sections are
loaded to dram instead of flash !
OUTPUT_FORMAT("elf32-powerpc", "elf32-powerpc",
"elf32-powerpc")
OUTPUT_ARCH(powerpc)
SEARCH_DIR(/usr/local/powerpc-rtems/lib);
ENTRY(start)
MEMORY
ram : org = 0x00000000, l = 4M
flash : org = 0x02800000, l = 2M
dpram : org = 0xFF000000, l = 16K
SECTIONS
.entry :
*(.entry)
. = ALIGN(0x10);
copy.src = .;
} > flash
/* IMPORTANT: section ".vectors" must be the first in RAM ! */
.vectors : AT (copy.src)
copy.dest = .;
*(.vectors)
. = ALIGN(0x10);
copy.tmptop.vec = .;
} > ram
.text : AT (copy.tmptop.vec - copy.dest + copy.src)
text.start = .;
*(.entry2)
*(.text)
*(.rodata)
*(.gnu.linkonce.r*)
*(.rodata1)
*(.gnu.linkonce.t.*)
*(.descriptors)
/* .gnu.warning sections are handled specially by elf32.em. */
*(.gnu.warning)
*(rom_ver)
etext = ALIGN(0x10);
_etext = .;
__CTOR_LIST__ = .;
LONG((__CTOR_END__ - __CTOR_LIST__) / 4 - 2)
*(.ctors)
LONG(0)
__CTOR_END__ = .;
__DTOR_LIST__ = .;
LONG((__DTOR_END__ - __DTOR_LIST__) / 4 - 2)
*(.dtors)
LONG(0)
__DTOR_END__ = .;
*(.lit)
*(.shdata)
*(.init)
*(.fini)
. = ALIGN(0x10);
_endtext = .;
text.end = .;
copy.tmptop.txt = .;
} > ram
text.size = text.end - text.start;
/* R/W Data */
.data : AT (copy.tmptop.txt - copy.dest + copy.src)
*(.data)
*(.data1)
*(.gnu.linkonce.d.*)
PROVIDE (__SDATA_START__ = .);
*(.sdata)
. = ALIGN(0x10);
copy.tmptop.dat = .;
} > ram
PROVIDE (__EXCEPT_START__ = .);
.gcc_except_table : AT (copy.tmptop.dat - copy.dest + copy.src)
*(.gcc_except_table)
. = ALIGN(0x10);
copy.tmptop.exc = .;
} > ram
PROVIDE (__EXCEPT_END__ = .);
__GOT_START__ = .;
.got : AT (copy.tmptop.exc - copy.dest + copy.src)
s.got = .;
*(.got.plt) *(.got)
. = ALIGN(0x10);
copy.tmptop.got = .;
} > ram
__GOT_END__ = .;
.got1 : AT (copy.tmptop.got - copy.dest + copy.src)
*(.got1)
. = ALIGN(0x10);
copy.tmptop.gt1 = .;
} > ram
PROVIDE (__GOT2_START__ = .);
PROVIDE (_GOT2_START_ = .);
.got2 : AT (copy.tmptop.gt1 - copy.dest + copy.src)
*(.got2)
. = ALIGN(0x10);
copy.tmptop.gt2 = .;
} > ram
PROVIDE (__GOT2_END__ = .);
PROVIDE (_GOT2_END_ = .);
PROVIDE (__FIXUP_START__ = .);
PROVIDE (_FIXUP_START_ = .);
.fixup : AT (copy.tmptop.gt2 - copy.dest + copy.src)
*(.fixup)
. = ALIGN(0x10);
copy.tmptop.fix = .;
} > ram
PROVIDE (_FIXUP_END_ = .);
PROVIDE (__FIXUP_END__ = .);
PROVIDE (__SDATA2_START__ = .);
.sdata2 : AT (copy.tmptop.fix - copy.dest + copy.src)
*(.sdata2)
. = ALIGN(0x10);
copy.tmptop.sda = .;
} > ram
copy.size = copy.tmptop.sda - copy.dest;
.sbss2 :
*(.sbss2)
} > ram
PROVIDE (__SBSS2_END__ = .);
__SBSS_START__ = .;
.bss :
bss.start = .;
*(.bss) *(.sbss) *(COMMON)
. = ALIGN(4);
bss.end = .;
} > ram
__SBSS_END__ = .;
bss.size = bss.end - bss.start;
/* reserve 16KByte for stack... */
stack.end = bss.end + 16K;
PROVIDE(_end = stack.end);
dpram :
m860 = .;
_m860 = .;
. += (8 * 1024);
} > dpram
.line 0 : { *(.line) }
.debug 0 : { *(.debug) }
.debug_sfnames 0 : { *(.debug_sfnames) }
.debug_srcinfo 0 : { *(.debug_srcinfo) }
.debug_pubnames 0 : { *(.debug_pubnames) }
.debug_aranges 0 : { *(.debug_aranges) }
.debug_aregion 0 : { *(.debug_aregion) }
.debug_macinfo 0 : { *(.debug_macinfo) }
.stab 0 : { *(.stab) }
.stabstr 0 : { *(.stabstr) }
It seems the "AT" command didn't work at all.
Can anybody tell me what's wrong with the precedure ?
How to build boot image for my board ?
(I'm using rtems-4.5.0-beta1c)
Thanks in advance !
Li HongSong
URL: <http://lists.rtems.org/pipermail/users/attachments/20000327/9cd03349/attachment.html>
