RTEMS web server linking error !
Ralf Corsepius corsepiu at faw.uni-ulm.de
Thu Mar 30 15:19:15 UTC 2000
Emmanuel Raguet wrote:
> Ralf Corsepius wrote:
> > > /opt/rtems/powerpc-rtems/bin/ld.exe -r -o o-optimize/temp.o
> > > o-optimize/init.o -b binary o-optimize/tarfile
> > => You are trying to link a tarfile. This will never work.
> Yes, it will work.
> I had the same problem but I have added the
> "--noinhibit-exec"
> option in the ld command and now it works fine.
Hmm, from ld.info:
--noinhibit-exec'
     Retain the executable output file whenever it is still usable.
     Normally, the linker will not produce an output file if it
     encounters errors during the link process; it exits without
     writing an output file when it issues any error whatsoever.
Does this give any sense?
May be I am missing something, but I am inclined to read this as
"suppress linking errors and ignore them".
Ralf
Ralf Corsepius
Forschungsinstitut fuer Anwendungsorientierte Wissensverarbeitung (FAW)
Helmholtzstr. 16, 89081 Ulm, Germany     Tel: +49/731/501-8690
mailto:corsepiu at faw.uni-ulm.de           FAX: +49/731/501-999
http://www.faw.uni-ulm.de
