gdb stub for 68360
Gus Paolone
gus.paolone at fujitsu.com.au
Wed Mar 1 22:31:11 UTC 2000
Hi Andrew;
Like you I was suppressed when gdb send those two commands. Then I
remembered that in an article in Embedded Magazine this was described as
not really being required. However I looked at the code that was
provided and put it in my stub. Then gdb was happy.
If you like to find the gdb "monitor" that was discussed in the article,
go to www.embedded.com and do a search on gdb. (sorry I cant remember
the month).
I hope this helps.
Gus
Andrew Bythell wrote:
> Gus Palone wrote:
> > > I have finally got a gdb monitor going on a 68360 target (needs some
> > > cleaning) and I can connect to it with gdb over a serial line.
> ...then you sound like someone who can help me with this problem (though
> I hope anyone will feel free to respond!). I'm not sure if the problem
> is with my stub or with my build of gdb.
> The Problem:
> I startup my target and it issues the packet $S07#ba , which gdb
> receives and is happy. But then gdb starts issuing commands that the
> m68k-stub doesn't support, like $qOffsets#4b and $Hc-1#09. If I
> manually issue these commands, the target returns +$#00$#00.
> The Question
> Do I need to add support for these commands to my stub, or do I need to
> modify gdb to send different commands? Alternatively, does anyone have
> proven source code for a 68360 stub that they would be willing to post?
> The Setup
> My original m68k-stub.c had the CVS tag Header: remcom.c,v 1.34 91/03/09
> 12:29:49 glenne Exp $
> and I am using gdb 4.17 configured as "--host=i586-pc-linux-gnu
> --target=m68k-rtems" with the appropriate rtems patch applied.
> Any input is appreciated,
> A.
> Andrew Bythell System Verification
> Nortel Networks Microelectronics Group
> Ottawa, Ontario Canada esn.39.56930
> tel.613.765-6930 fax.613.763-7795
